300-793_ALT_0
300-793_ALT_1
300-793_ALT_2
300-793_ALT_3
300-793_ALT_9
250W Subwoofer Amplifier w/Remote Control
Brand:|Part # 300-793
This high performance subwoofer amplifier allows you to adjust the volume and crossover frequency from the comfort of your favorite chair! Making subwoofer adjustments between music and movie soundtracks has never been easier!
Part # 300-793
  • IR remote control
  • Remote mountable control panel
  • High power Class AB amplifier
  • Phase switch
  • Gold plated connectors
  • High-pass filter for satellite speakers
  • Line level outputs
This item has been discontinued. For possible replacements or substitutions, please check the drop-down box below for a list of related items to view more products in this category. This high performance subwoofer amplifier allows you to adjust the volume and crossover frequency from the comfort of your chair! Adjustments between music and movie soundtracks has never been easier. The control panel, designed to be mounted on the front of the enclosure, houses motorized volume and frequency controls as well as the IR pick-up for the remote control. A class AB design produces clean, earth-shaking bass. The amp features gold-plated high and low level inputs, adjustable phase between 0° and 180°, gain control, auto on/off, and a 12 dB/octave electronic low pass filter that is variable from 40 to 170 Hz. Also featured is a 6 dB high pass filter (125 Hz @ 8 ohm) output for satellite speakers and a line level output with high pass filter for loop-through to the main power amp. Built-in thermal overload and fuse protection offer years of reliable use. Right and left stereo inputs are summed to a mono output; only one amp is required per system. Air leaks are prevented with the use of high-density foam on the pre-amp board and mounting plate.
  • BrandParts Express
  • Part Number300-793
  • UPC844632000669
  • Product CategoryHome Audio Amplifiers
  • Weight16.41 lbs.
View similar products to the 250W Subwoofer Amplifier w/Remote Control
in the Home Audio Amplifiers product category.
