120-055_ALT_0
24 VDC 5A Switching Power Supply with 2.5 x 5.5mm Plug
This regulated 24 VDC 5A power supply is ideal for replacing lost or damaged power supplies from your electronic devices or as a foundation for new projects.
  • Efficient and reliable switching power supply
  • UL listed, CE and FCC approved
  • 24 VDC regulated output at 5 Amps
  • 2.5 mm x 5.5 mm x 9 mm plug
120-055
Weight: 1.65 lbs.
IN STOCK
List Price$39.99
You Save25%
$29.90
Buy 4-up$28.41
Part # 120-055
Switching power supplies are reliable, compact, and efficient. This regulated 24 volt DC 5A power supply provides ample current to run many popular devices and accepts inputs 100~240 VAC. Use it to replace a lost or damaged power supply for AV equipment, office devices, battery chargers, and other electronic components. Approved/listed by all major safety agencies; UL, CUL CE, and FCC. Detachable 6 ft. input cord. Output connector: 2.5 mm x 5.5 mm x 9 mm, center positive.
  • DC Output Voltage24V
  • Current Capacity5000 mA
  • Center/Tip PolarityCenter (+)
  • Plug Size2.1 x 5.5 mm
  • Input Voltage100~240 VAC VAC
  • BrandParts Express
  • Part Number120-055
  • UPC844632005640
  • Product CategoryAC/DC Power Adapters
    (1 Reviews)
  • Weight1.65 lbs.
View similar products to the 24 VDC 5A Switching Power Supply with 2.5 x 5.5mm Plug
in the AC/DC Power Adapters product category.
24 VDC 5A Switching Power Supply with 2.5 x 5.5mm Plug is rated 3.0 out of 5 by 1.
Rated 3 out of 5 by from Nice Power Brick - for the right applicationWell built; sturdy. Quite large. Unfortunately I can't recommend this for at least one application. I purchased this on member recommendation as an upgrade to the stock unit that comes with the Bravo Audio V2 Headphone Amp at PE. Whether or not it was this particular unit (which I returned) - the signal noise it induced in the Amp as heard in my earphones was simply too great to ignore - much more audible than the stock unit, and was present at all times. So it may be a great, sturdy DC power supply, but make sure you have the right application for it.
Date published: 2014-04-15
What is the connector size?
The title says 2.5mm, but the description says 2.1mm. Which is it? Are they interchangeable?
Asked by: Gibson486
The connector is 2.5 x 5.5 mm. Sorry for the confusion.
Answered by: PE Tom
The title says "2.5 x 5.5mm Plug", but the description says "2.1 mm x 5.5 mm". Which one is it? Are they interchangeable?
Asked by: Gibson486
This is a 2.5 mm x 5.5 mm plug.
Date published: 2012-12-12
will this powersupply work for "Dayton Audio DTA-120 Class T Digital Mini Amplifier 60 WPC Brand: Dayton Audio | Model: DTA-120" amplifier.
Asked by: castle
Yes this will work for the DTA-120 amplifier.
Date published: 2014-03-12
Is this a efficient way to have a stable power forĀ 2x100W at 4 Ohm TK2050 Class-D Audio Amplifier Board (TK2050 chipset) ?
Asked by: Alex8787
This will power the amplifier but will not allow full output due to its 5A current rating.
Date published: 2014-04-14
Customer projects that include: 24 VDC 5A Switching Power Supply with 2.5 x 5.5mm Plug
