120-054_ALT_0
24 VDC 1880mA Switching Power Supply US and EU
Brand:|Part # 120-054
This 24 VDC power supply features a generous 1880 mA (1.88 A) current capability and includes plugs that make it useful throughout much of the world.
List Price$24.99
You Save32%
$16.98
Buy 4+$16.45
Part # 120-054
  • 24 VDC regulated power supply
  • Compact form factor
  • Plugs included for international use
This regulated switching power supply delivers up to 43 watts of power using either US standard 60 Hz, 110/120 VAC or European standard 50 Hz, 220/240 VAC. Snap-in power plugs are included for operation in the US, Europe, UK, and Australia. 6 ft. connection cable with 2.5 mm x 5.5 mm plug. This power supply is both CE and UL rated.
  • DC Output Voltage24V
  • Current Capacity1880 mA
  • Center/Tip PolarityCenter (+)
  • Plug Size2.5 x 5.5 mm
  • Input Voltage100~240 VAC
  • BrandParts Express
  • Part Number120-054
  • UPC844632098574
  • Product CategoryAC/DC Power Adapters
  • Weight0.7 lbs.
View similar products to the 24 VDC 1880mA Switching Power Supply US and EU
in the AC/DC Power Adapters product category.
Can this adaptor be used like my old one - input 120vac 60 ha 0.28 A, output 24vac 1500mA
Asked by: Laurie
This adapter would not be compatible. This is a DC output where your specs would indicate an Ac output.
Answered by: Chrisf
Date published: 2015-02-17
can i use this to power the 4x100W TDA7498 Class-D Amplifier Board
Asked by: marc50
I would not recommend this power supply for that amplifier. The minimum recommended current draw for that amp is about 6 amps, this power supply provides less than two. The ideal power supply for it would be this:http://www.parts-express.com/24-vdc-146a-350w-regulated-switching-power-supply--320-316
Date published: 2014-11-19
Will this work as a replacement for a Plug in class 2 transformer.  Input:  AC 120V 60Hz 500mA, Output:  DC 24V 1.5A 36VA?
Asked by: cwyman1
Yes this will work fine as a replacement for that transformer.
Date published: 2014-02-12
power.
Can i use this with a 2x50W TDA7492 Class-D Amplifier Board (part number 320-301) and get full output
Asked by: speaker freack
Unfortunately, no this ps will not work with that amplifier board for full output. However if you were to run within the THD into 8 ohm speaker ie 2 x 20W (40W) you might get away with it. However I would not risk it. An 8 ohm speakers are never a steady 8 ohms and if you are playing heavier bass music it is much better to have the current if the amplifer needs it.At minimum I suggest PE# 120-055 and some filtering caps, or use the recommended supply PE# 320-314.
Answered by: JDoyner
Date published: 2013-08-29
Can this be used as a pinball machine power supply? DC 24V 2.5A 60W?
Asked by: Aria
This entirely depends on the power requirements for the pinball machine. If it requires 24VDC and less than 2.5A current draw, yes this will work.
Date published: 2013-11-05
Can this PSU be used for audio circuits?
Asked by: tomgarneau
I see no reason why not. Switching power supplies have been known for introducing noise into an audio type circuit although this is not always the case.
Date published: 2013-05-01
  • 2016-02-09T07:18CST
  • co_hasquestionsanswers, tq_6
  • loc_en_US, sid_120-054, PRD, sort_recentQuestionsFirst
