22/2 Shielded Mic/Line Cable 250 ft.
Brand:|Part # 100-244
Popular interconnect cable suits a variety of audio applications. Ideal for balanced/unbalanced line level audio, as well as permanently installed microphone connections under floors, in walls, or in racks.
List Price$54.99
You Save29%
$39.12
Buy 4+$35.40
Part # 100-244
  • Industry-standard 22 AWG two-conductor wire
  • For balanced or unbalanced audio applications
  • Flame retardant gray PVC jacket, .137" nominal O.D.
  • Footage sequentially printed on cable in 2 ft. increments
  • Stranded bare copper conductors (7/30 per conductor)
  • PE insulation
  • 100% aluminum/polyester foil shield
Popular interconnect cable suits a variety of audio applications. Overall foil/polyester wrap provides effective shielding. Durable, easy-to-pull PVC jacket facilitates long cable runs. Ideal for balanced/unbalanced line level audio, as well as permanently installed microphone connections under floors, in walls, or in racks.
  • Wire Gauge22 AWG
  • Jacket ColorGray
  • Length250 ft.
  • BrandParts Express
  • Part Number100-244
  • UPC844632003820
  • Product CategoryMicrophone Cable & Signal Cable
    (5 Reviews)
  • Weight5 lbs.
View similar products to the 22/2 Shielded Mic/Line Cable 250 ft.
in the Microphone Cable & Signal Cable product category.
22/2 Shielded Mic/Line Cable 250 ft. is rated 4.2 out of 5 by 5.
Rated 5 out of 5 by from Perfect for fixed installationsNice product. Useful for fixed installations such as inside racks or for in ceilings, under stages, etc. in venues.
Date published: 2014-02-05
Rated 3 out of 5 by from Not Exactly as picturedI've been using this cable for a long time and it turns out to be good for stationary wiring. However, its quality has gone down. In the picture and description it is listed as having stranded wires, including the shield drain wire. In fact what is shipped now has a much thinner solid drain wire, not nearly as robust. Further, the foil shielding seems to be a lot more brittle. I don't know when the transition took place, but my reel dated 12/08 has a stranded drain wire and my roll dated 01/10 has a solid drain wire.
Date published: 2011-11-19
Rated 4 out of 5 by from It works GreatI used it for my home studio. Phantom power doesn't always behave well through it, but it's probably me and my connections on my XLR plugs. The alumunum shielding is a little cumbersome; next time I'm going to get copper shielded wire so I can wrap it better.I've also used this wire to build 20' XLR mic cables to use for micing my drum kit. It was way cheaper to get the plugs and wire my own than buy them. Again, the dynamic mics work better, but it's just my shoddy workmanship, I'm sure!! LOL.
Date published: 2010-03-27
Rated 4 out of 5 by from Good stuffUsed to wire my home recording studio and worked great.
Date published: 2008-12-16
Rated 5 out of 5 by from Very versatile, easy to use.I've used this cable for everything from mic lines to headphone lines in my basement recording studio. It's also been used in PA amplifier racks, and for routing cables in a FOH PA.Great stuff, VERY easy to work with, DEAD silent, even when running right next to power. I like it.
Date published: 2008-03-10
  • 2016-02-08T06:48CST
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_100-244, PRD, sort_mostRecent
