2.1mm x 5.5mm x 11.2mm DC Plug with 6 ft. Cord
2.1 mm x 5.5 mm x 11.2 mm plug with 6 ft. cord.
090-489
Weight: 0.0792 lbs.
IN STOCK
$1.59
Buy 10-99 $1.38
Buy 100-up$1.25
Part # 090-489
  • DC Power Connector TypePlug
  • BrandParts Express
  • Part Number090-489
  • UPC844632011542
  • Product CategoryDC Power Connectors
    (11 Reviews)
  • Weight0.0792 lbs.
View similar products to the 2.1mm x 5.5mm x 11.2mm DC Plug with 6 ft. Cord
in the DC Power Connectors product category.
2.1mm x 5.5mm x 11.2mm DC Plug with 6 ft. Cord is rated 4.5455 out of 5 by 11.
Rated 5 out of 5 by from UsefullCheep, good constriction, very useful for powering guitar pedals
Date published: 2014-01-28
Rated 5 out of 5 by from Great PlugI used these to replace some plugs for a friend that was chewed up by a dog.They work great and was just like what the power supply had on it.Made them very happy to have them fixed they fit every device just like the original plug did.
Date published: 2012-08-16
Rated 5 out of 5 by from WorksUsed this cable to rig up a battery for a stealthcam trail camera. Does the job.
Date published: 2013-01-27
Rated 4 out of 5 by from Good valueThis is the standard size plug for most 12 volt consumer networking products and many LCD monitors among other things.I use a couple hundred a year. They are 24 gauge wire. I find faults in 1-3% of them. I don't consider this bad considering the price. You should ring out each one for continuity, polarity and shorts before putting it in service.
Date published: 2011-12-15
Rated 5 out of 5 by from Right angle prevents breakageI needed this for my Celestron CG-5ASGT telescope mount. The straight plugs have a habit of getting hit and either unplugged or broken as a result. This right angle plug cures that problem.For my fellow telescope friends, this item is a must.
Date published: 2011-02-17
Rated 5 out of 5 by from Excelent value and repair partI had to buy 2 sizes to repair a dell laptop power adapter. It was such a good value I ordered 2 of each size (its hard to measure half mm with normal tools) and still came out ahead. I have 1 spare for when this one may fail and 2 a different size for future.
Is this cable round with both conductors in the same jacket or is it two separate conductors running parallel and fused together (flatter)?
Just wondering if this cable has a completely round jacket with both conductors inside or if it is a parallel cable where two conductors are individually insulated and fused together so the cable has a "flatter" appearance.Thanks!
Asked by: Davidgill
This cable is made from two separate conductors that are fused together. The center contact is the wire with a white stripe and the ground sleeve is the black wire.
Date published: 2012-06-28
I'm going to use this for my Lepai T-amp
Should the inside be ground and outer shielding positive?
Asked by: Joel1316
This needs to be wired center positive for the Lepai amplifiers.
Date published: 2012-12-14
I'm considering using this for my guitar's effects board. Is there a shorter version than 6 ft??
Asked by: ericstrand10
Unfortunately no, however you can simply cut the cord to whichever length you may need for your application.
Date published: 2013-11-22
does the 090-489 fit the 090-488
Asked by: N2OG
Yes these are both compatible.
Date published: 2014-02-24
What gauge are the conductors in these cords?
Asked by: Deuce
Each conductor is 24 AWG.
Answered by: RussR
Date published: 2011-05-27
Customer projects that include: 2.1mm x 5.5mm x 11.2mm DC Plug with 6 ft. Cord
