090-488_ALT_0
2.1mm Panel Mount DC Jack
DC power connector. 2.1 mm, panel mount jack.
090-488
Weight: 0.0066 lbs.
IN STOCK
$1.75
Buy 10-99 $1.59
Buy 100-up$1.32
Part # 090-488
  • DC Power Connector TypeJack
  • BrandParts Express
  • Part Number090-488
  • UPC844632010958
  • Product CategoryDC Power Connectors
    (10 Reviews)
  • Weight0.0066 lbs.
View similar products to the 2.1mm Panel Mount DC Jack
in the DC Power Connectors product category.
2.1mm Panel Mount DC Jack is rated 3.6 out of 5 by 10.
Rated 2 out of 5 by from CheapWorks, but be aware the case is not isolated from ring connector. must always use for neg/ground.
Date published: 2013-10-30
Rated 1 out of 5 by from FragileThis jack self-destructed when I pulled ever so slightly on one of the wire leads, to test the solder connection.
Date published: 2013-07-31
Rated 2 out of 5 by from Didn't make it to the gameI purchased one to fix a basketball possession arrow's Power connector. This was to be the third (different) connector. My co worker soldered it up and went to plug it in to test it and it broke into two pieces. Glad it was on the bench and not at the game. Now looking for a heavier connector. As always parts express's shipping was quick. I will continue to shop with them. Just too light of a part for our job.
Date published: 2013-02-08
Rated 5 out of 5 by from Battery or AC optionI'm using this jack to power my portable speakers that use a built in battery or AC power source. The internal amp will run off the battery if nothing is plugged in, and run off the AC power source when plugged in. Once the AC source is unplugged it switches to the battery source. Exactly what i was looking for.
Date published: 2012-02-28
Rated 5 out of 5 by from Excellent productI use the jacks for replacement and installment. The jacks are good quality and easy to install.
Date published: 2009-07-22
Rated 5 out of 5 by from Works just fineIt does what it does at a low price and hasn't cause me any trouble. What more can you ask for?
Date published: 2009-03-19
is this for a 12v wall adapterĀ
Asked by: caimartin
Yes this can work with an A/C adapter that has a plug size of 2.1mm x 5.5mm.
Date published: 2014-04-04
Why are there 3 solder lugs on a DC jack? Which is outer sleeve and which is inner sleeve? What is the purpose of the third lug?
See rear view detail photo, it shows all three lugs.
Asked by: Jediok
Two of these lugs are a ground, both are not required for this to work properly.
Date published: 2013-10-28
How do you wire correctly?
Asked by: Drake
Some electronic devices are wired (-) ground and some are (+) ground. Be sure how your device is wired before installing this power jack.Typically, in order to avoid accidentally shorting the recessed center post is (+). Simply solder the (+) wire to the (+) tab and the (-) to the (-) tab and you are done. If your device requires a chassis mount then you can use a jumper wire as detailed above or search PE for a chassis mount jqck.
Answered by: Nitnub
Which Universal AC adapter would work best with this, 2.1mm x 5.0mm or 2.1mm x 5.5mm?
Asked by: VincenT
We recommend a 2.1mm x 5.5mm plug, the one linked below would be a solder-on plug we suggest using with this jack.
Answered by: RussR
Date published: 2012-02-07
What are the voltage and current ratings on the 090-488?
Asked by: slightner
These units are rated for 12-24VDC, approximately 3 amperes.
Answered by: RussR
What is the mounting diameter and maximum panel thickness for 090-488?
Asked by: slightner
The required mounting hole will be approximately 8mm or 0.315". Maximum panel thickness is going to be approximately 3.5mm or 0.140", roughly 1.15mm or 0.045" less if using the included split lock washer.
Answered by: RussR
Customer projects that include: 2.1mm Panel Mount DC Jack
Related Products
Customers Also Bought
12 VDC 1200mA AC Adapter
Part # 129-083
2.5mm Panel Mount DC Jack
Part # 090-479
