CLEARANCE
090-481_ALT_0
090-481_ALT_1
2.1mm Center Pin In-Line DC Jack
Brand:|Part # 090-481
2.1 mm center pin, in-line jack.
$1.79
Buy 10-99 $1.46
Buy 100+$1.07
Part # 090-481
  • DC Power Connector TypeJack
  • BrandParts Express
  • Part Number090-481
  • UPC038975482576
  • Product CategoryDC Coaxial Power Connectors
    (6 Reviews)
  • Weight0.0198 lbs.
View similar products to the 2.1mm Center Pin In-Line DC Jack
in the DC Coaxial Power Connectors product category.
2.1mm Center Pin In-Line DC Jack is rated 3.8333 out of 5 by 6.
Rated 1 out of 5 by from Doesn't work with parts-express 2.1/5.5 plugsThese work with some other 2.1/5.5mm plugs but the sizing is slightly off. Tech support has confirmed that they don't work with the parts-express 2.1/5.5mm plugs because _all_ of them are currently mis-sized. But they still list these as in stock. I'll be happy to rescind/update my review when this is fixed but it's crazy that this is currently listed as available.
Date published: 2014-03-14
Rated 5 out of 5 by from easier way to solder has been found.i was looking for some of these in both the 2.1 and 2.5mm versions and saw that everyone was complaining about pin drift while soldering. i just plug in an old male 2.1/2.5mm plug that is dead and do my work while they are connected. still cant dwadle away time, but atleast they wont distort and melt as easily that way. hope this helps!!
Date published: 2010-09-23
Rated 5 out of 5 by from Great solution!!I'm a musician and I had been looking for a solution to the short AC adapter cords, that lay precariously in the middle of the stage floor....so I was looking for some kind of extension to take them out of the way, and found it!!! now my AC adapters are out of harm's way and work great, as the conection is tight and reliable!!!
Date published: 2009-07-23
Rated 2 out of 5 by from Soldering middle pin?It was easy to solder the outside pin but I never could get the inside pin to accept the solder and there are no mechanical means to hold the inside pin and wire.
Date published: 2009-03-30
Rated 5 out of 5 by from Good quality quick delivery.Just what I needed together with the 2.5mm center pin plug I also ordered to make a power adapter for my Toshiba laptop Don't leave the heat on too long when soldering or the center pin will drift in the dielectric like a coax plug will.
Date published: 2008-06-29
Rated 5 out of 5 by from As described and picturedGreat.
Date published: 2008-03-17
  • 2016-02-05T06:45CST
  • co_hasreviews, tv_0, tr_6
  • loc_en_US, sid_090-481, PRD, sort_mostRecent
