20 Ohm 10W Resistor Wire Wound 5% Tolerance
Brand:|Part # 016-20
20 ohm 10 watt wirewound resistor with 5% tolerance. Sold individually.
$0.78
Buy 10-49 $0.64
Buy 50+$0.48
Part # 016-20
  • Exceptionally small, sturdy, and reliable
  • Ceramic flame retardant package
  • Sealed with a special quartz mixed sand cement
  • Excellent moisture resistance
  • High temperature stability
  • 5% tolerance
  • Temperature Range: -55°C ~ +155°C
20 ohm 10 watt wirewound resistor. Through-hole termination with axial leads. 5% tolerance. RoHS compliant. Dimensions (mm): Case: 49 L x 10 W x 9 H (±1); Lead length: 35 (±5). Sold individually.
  • Resistance20 ohms
  • CompositionWirewound
  • Power Rating10 Watt
  • Tolerance5%
  • BrandXicon
  • Part Number016-20
  • UPC844632060342
  • Product CategoryWire-wound Resistors
    (1 Reviews)
  • Weight0.0013 lbs.
View similar products to the 20 Ohm 10W Resistor Wire Wound 5% Tolerance
in the Wire-wound Resistors product category.
20 Ohm 10W Resistor Wire Wound 5% Tolerance is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Just what the doctor orderedI had just about hit a dead end buy new or finding somebody to repair a crossove in old set of fender p.a. speakers I had. I knew I needed resistor but had no idea where to look. I found parts express. If it weren't for the ease of the parts search I would not be usuing the speakers anymore.Thanks to parts express they are in full use takin' a knockin' and still rockin'!THANKS PARTS EXPRESS YOU ROCK!!!
Date published: 2007-09-05
  • 2016-02-08T06:59CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_016-20, PRD, sort_mostRecent
