BUYOUT
299-009_ALT_0
299-009_ALT_1
2" Full Range Speaker 25 Ohm
Brand:|Model: P0050025FM19BAR|Part # 299-009
Designed for use in telecom/VOIP devices, this low profile 2" extended range speaker features a 25 ohm voice coil, providing a very easy load to drive for just about any amplifier. Works great as a line array driver or headphone element, perfect for unique audio projects.
List Price$3.99
You Save75%
$0.99
Part # 299-009
  • Unique 25 ohm impedance for use as a headphone element
  • Minimum frame for use in line arrays
  • Remarkable output from 500 to 3,000 Hz
  • Originally built for use in VoIP phones and intercoms
This low profile 2" extended range speaker is designed for use in telecom/VOIP devices, where voice capture and playback is the primary design focus. A 25 ohm voice coil is used to allow this driver to be used in many different intercom applications, while providing a very easy load to drive for just about any amplifier.
Additionally, this speaker can be driven to a moderate level using a smartphone or portable music player, making it a great choice for building your own headphones. A headphone amplifier is recommended for louder than moderate volume requirements.
The press-fit faceplate design minimizes center-to-center mounting distance to 2". This allows for line array use up to around 6,500 Hz without comb filtering issues, while 500 to 3,000 Hz frequency response allows it to be used as an upper midrange in multi-way loudspeakers. A weather-resistant design allows this driver to be used in high humidity outdoor applications. Two 2-3/8" long, 24 AWG leads are pre-soldered onto the driver for simple connection.
Save 75% off the manufacturer's original retail price through this exclusive Parts Express factory buyout. Hurry, quantities are limited!
Note: For higher power handling and sensitivity, it is recommended that this driver be used wired together in groups. Four of these wired in parallel will increase full range power handling to 2 watts RMS, 4 watts max and yield a 6 ohm impedance. Using a high pass filter will also increase power handling.
  • Nominal Diameter2"
  • Power Handling (RMS)0.50 Watts
  • Power Handling (max)1 Watts
  • Impedance24 ohms
  • Frequency Response500 to 3,000 Hz
  • Sensitivity83 dB 1W/1m
  • Voice Coil Diameter0.39"
  • Resonant Frequency (Fs)291 Hz
  • DC Resistance (Re)19 ohms
  • Voice Coil Inductance (Le)0.96 mH
  • Mechanical Q (Qms)7.83
  • Electromagnetic Q (Qes)1.88
  • Total Q (Qts)1.52
  • Cone MaterialPoly
  • Basket / Frame MaterialPolymer
  • Overall Outside Diameter1.97"
  • Baffle Cutout Diameter1.83"
  • Depth0.63"
  • BrandFactory Buyouts
  • ModelP0050025FM19BAR
  • Part Number299-009
  • UPC848864013848
  • Product CategoryMini Speakers
  • Weight0.1000 lbs.
View similar products to the 2" Full Range Speaker 25 Ohm
in the Mini Speakers product category.
Part # 299-009
