289-124_ALT_0
289-124_ALT_1
2" Full Range Aluminum Cone Neodymium Driver
Brand:|Part # 289-124
Full range driver with 1" voice coil and aluminum cone. The soft rubber edge and flat spider help achieve a full 1.5 mm of Xmax, and the neodymium magnet permits placement next to sensitive equipment.
Comparable Items In Stock:
Part # 289-124
  • Neodymium magnet
  • Anodized aluminum cone
  • Gray rubber surround
  • Flat spider
  • Stamped steel frame
  • 5" wire lead with connector
  • 1" voice coil
Full range driver with 1" voice coil and aluminum cone. The soft rubber edge and flat spider help achieve a full 1.5 mm of Xmax, and the neodymium magnet permits placement next to sensitive equipment. Conservative 5 watt power rating. Perfect for compact speaker projects or line arrays.
Specifications: • Power handling: 5 watts RMS/10 watts max • VCdia: 1" • Le: 0.18 mH • Impedance: 8 ohms • Re: 7.57 ohms • Frequency response: 147-14,000 Hz • Fs: 147 Hz • SPL: 82.6 dB 1W/1m • Vas: 0.011 cu. ft. • Qms: 2.42 • Qes: 0.84 • Qts: 0.62 • Xmax: 1.5 mm •Dimensions: Overall diameter: 2-1/4" (2-7/8" diagonally ear-to-ear), Cutout diameter: 2-1/16", Depth: 1-1/4".
  • BrandFactory Buyouts
  • Part Number289-124
  • UPC844632077296
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (12 Reviews)
  • Weight0.4 lbs.
View similar products to the 2" Full Range Aluminum Cone Neodymium Driver
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
