2-1/2" Poly Dust Cap
2-1/2" Poly Speaker Dust Cap
Replace damaged or aging dust caps with these high grade textured polymer units. This 2 1/2" dust cap is most commonly used for 5 1/4" to 6 1/2" woofers.
260-382
Weight: 0.0013 lbs.
IN STOCK
$1.25
Buy 10-49 $0.98
Buy 50-up$0.75
Part # 260-382
Replace damaged or aging dust caps with these high grade textured polymer units. Use our Speaker Repair Glue (340-076) for paper cones or Black Rubber Cement (340-078) for poly cones. This size dustcap is most commonly used with 5-1/4" to 6 1/2" speakers.
  • BrandParts Express
  • Part Number260-382
  • UPC844632013324
  • Product CategoryDust Caps
    (6 Reviews)
  • Weight0.0013 lbs.
View similar products to the 2-1/2" Poly Speaker Dust Cap
in the Dust Caps product category.
2-1/2" Poly Speaker Dust Cap is rated 4.8333 out of 5 by 6.
Rated 5 out of 5 by from Worked GreatPoly Speaker Dust Cap were just as described and worked great.
Date published: 2014-09-02
Rated 5 out of 5 by from Easiest repair everUsed on my 20 year old AR m1's and couldn't be happier.
Date published: 2014-02-11
Rated 5 out of 5 by from Very niceI used these to replace the dented dust caps on my JVC SX-F50 tower speakers. They were very easy to glue on. Took about 3 minutes each. They do not come with glue but I had some left over from replacing surrounds on a pair of Cerwin-Vegas! They material is shiny and pretty stiff. I wish they had a smaller size as they look pretty huge on my 7 inch woofers.
Date published: 2010-07-09
Rated 4 out of 5 by from Good for the valueI was painting my 5 1/4 woofers black to match my see through grill and painted the original dust cap. There was drop in horn frequencies because I realised that the dust cap was acoustically transparent, allowing sound to pass directly through them. I bought these as a replacement and noticed that the material was solid all the way through, though the stiffness more than made up for horn frequencies. In fact, they're too bright in that area. (Crossover was set at 3500 Hz.) I'd recommend these only for replacement of solid dust caps, lower crossovers or if you have an equalizer to bring the horn freq. down.
Date published: 2009-10-26
Rated 5 out of 5 by from Simple fix for bad dust capsMy AR M2 speakers had a 2" rubber dust cap that rotted out. Removed the remains of the old caps and covered the hole with these 2 1/2" poly cap. Just superglued them in place. The speakers look like that always had them, perfect repair. Only problem was I thought I was only shipped one, the caps nest very tightly and the plastic is thin, to keep the weight to a minimum, it really looked like I only had one cap. Separating them into 2 pieces took a few moments but they eventually did seperate.
Date published: 2008-09-25
Rated 5 out of 5 by from Nice Poly Caps That Work Just FineI searched endlessly to find a polypropylene dust cap that would be a perfect match for my polypropylene mid range woofer when I stummbled across partsexpress' range of dust caps. They are a perfect match and come in various sizes. Thanks for providing me these.
Date published: 2008-07-09
We need a poly dust cap 1,18" (3 cm). Are the inches on the site, the size of the speakers or from the dust cap? If it is from the dust cap, did you have a dust cap for us which will fit?
Asked by: Barbara
The sizes listed on our dust caps are the actual diameters of the caps themselves, not for the speakers they fit on.
Date published: 2014-04-09
i am looking to replace dust cap of the 6 1/2inch woofer of my jbl ti6k speaker.the size if the dust cap is 2inch diameter.which dust cap should i ord
Asked by: rajd
If the dust cap is plastic, then this product would be suitable. If it's a paper dust cap, we do have a paper 2-1/2" cap as well, linked below for your convenience.
Answered by: RussR
Date published: 2011-10-19
Customer projects that include: 2-1/2" Poly Speaker Dust Cap
