1K Ohm Potentiometer
1K Ohm Potentiometer 1/4" Shaft
Brand:|Part # 023-510
1K ohm linear taper 1/2 watt potentiometer. Shaft length: 19/32" (15 mm).
$1.79
Buy 10+$1.60
Part # 023-510
• Shaft length from the body: 19/32" (15 mm) • Diameter of body: 31/32" (24 mm) • Front to back depth of body: 7/16" (6 mm) • Fits 5/16" mounting hole.
  • Electrical CharacteristicsLinear Taper
  • Value1K Ohm
  • BrandParts Express
  • Part Number023-510
  • UPC844632011276
  • Product CategoryPotentiometers
  • Weight0.0462 lbs.
View similar products to the 1K Ohm Potentiometer 1/4" Shaft
in the Potentiometers product category.
replaced 2 potentiometer on electric golf cart, why do they fail after 2 years use?
Asked by: tenmeg
Things such as dirt and moisture can cause premature failures. If used according to the amp rating and in a secure environment they will last several years. Less than this will effectively shorten their life. The answer depends on your circumstances.
Answered by: Nitnub
Date published: 2012-08-03
what is the diameter of the shaft on this potentiometer?
Asked by: PL 71 fan
This product will have a 1/4" shaft.
Answered by: RussR
Date published: 2012-05-24
I have an old potters wheel that has a mechanical foot pedal attached to a speed control. Will this product work to replace the speed control?
Wires have been soldered on.The speed control has written on it: 1KΩLIN B5.I am from the UK. Does this matter?Thanks
Asked by: LauraSybilHuston
if you're just looking to replace the potentiometer, then it should work.
Answered by: Silverback
Date published: 2011-10-08
  • 2016-02-13T08:03CST
  • loc_en_US, sid_023-510, PRD, sort_recentQuestionsFirst
Part # 023-510
