BUNDLE
300-584_ALT_0
300-584_ALT_1
300-584_ALT_2
300-584_ALT_3
300-584_ALT_4
300-584_ALT_5
300-584_ALT_6
15" Wireless Subwoofer Bundle - Dayton Audio SUB-1500 15" 150W Powered Subwoofer + Sub-Link XR
Brand:|Part # 300-584
Positioning your subwoofer just got easier, with the Dayton Audio wireless subwoofer package. Two great products come together to add punchy, clean bass to your home theater setup. Installation is easy and the results will blow you away.
List Price$389.99
You Save38%
$242.50
Part # 300-584
  • 150 watt self-powered 15" subwoofer with wireless transmitter and receiver
  • Downward-firing flared port design for clean, powerful bass
  • Selectable "Auto-on" mode
  • Perfect for home theaters or listening rooms
  • All audio and power cables included for wireless signal transfer
Your subwoofer setup no longer has to be limited by long cables. With the Dayton Audio wireless subwoofer package, you can place your subwoofer anyplace there is an AC outlet. The setup is simple; just plug the included 3.5 mm to RCA stereo cable into the line out of your receiver and connect it to the Sub-Link XR transmitter.
The transmitter can be powered by the included USB cable/AC adapter, or directly by a USB port on your receiver. Next, place the subwoofer near any outlet within 40 ft. line-of-sight and connect the Sub-Link XR receiver. This can be powered the same way as the transmitter. Connect the receiver to the subwoofer using the included stereo or mono RCA cable. Now, pair the transmitter to the receiver and you are ready to go.
Subwoofer Specifications: • Power output: 150 Watts RMS * Frequency response: 23-140 Hz • Box design: Ported • Inputs: RCA line level & speaker level • Outputs: Speaker level • Crossover frequency control: Continuously variable from 40 Hz to 140 Hz @ 12 dB/octave • Phase switch: 0/180 degrees • Power switch: On/Auto/Off • Power requirements: 120VAC, 60 Hz • Dimensions: 19-3/4" H x 19-1/4" W x 19-3/4" D.
Sub-Link XR Specifications: • Transmitter / Receiver operating voltage: 5V DC, 1A • RF frequency band: 2.404 to 2.467 GHz • Modulation: GFSK • Working distance: 12 meters (40 feet; unobstructed line-of-sight) • Transmitter power: ≤ 10 dBm • Transmitter input sensitivity: 700 mV @ 1% THD • Receiver sensitivity: -85 dBm • Frequency response: 15 to 20,000 Hz +1/-3 dB • Delay time: <25ms • THD+N: -60 dB @ 1 kHz. • Dimensions per Unit: 2-5/8/" L x 2" W x 1/2" H.
15" Wireless Subwoofer Bundle - Dayton Audio SUB-1500 15" 150W Powered Subwoofer + Sub-Link XR includes the following items:
Qty Part # Item
1300-580Dayton Audio Sub-Link XR 2.4 GHz Wireless Audio Transmitter Receiver System for Subwoofers
1300-634Dayton Audio SUB-1500 15" 150 Watt Powered Subwoofer
  • Woofer Diameter15"
  • BrandDayton Audio
  • Part Number300-584
  • UPC848864017181
  • Product CategoryPowered Subwoofers
    (4 Reviews)
  • Weight61.0000 lbs.
View similar products to the 15" Wireless Subwoofer Bundle - Dayton Audio SUB-1500 15" 150W Powered Subwoofer + Sub-Link XR
in the Powered Subwoofers product category.
