090-484_ALT_0
1.3mm x 3.5mm x 9mm Plug with 6 ft. Cord
1.3 mm x 3.5 mm x 9 mm plug with 6 ft. cord.
  • DC plug with attached 6 ft. cord for easy installation
090-484
Weight: 0.0924 lbs.
OUT OF STOCK
Due In: 11/14/2014
$1.98
Buy 10-99 $1.89
Buy 100-up$1.49
Part # 090-484
  • DC Power Connector TypePlug
  • BrandParts Express
  • Part Number090-484
  • UPC038975480046
  • Product CategoryDC Power Connectors
    (4 Reviews)
  • Weight0.0924 lbs.
View similar products to the 1.3mm x 3.5mm x 9mm Plug with 6 ft. Cord
in the DC Power Connectors product category.
1.3mm x 3.5mm x 9mm Plug with 6 ft. Cord is rated 4.0 out of 5 by 4.
Rated 5 out of 5 by from Quick way to connect LED lights w/ coaxial power plugThis cable solved my need for a longer than three foot cable that came with my LED under cabinet lights. It plugs into the socket on the fixture allowing a splice connection on the other end. The LED lights are only 3 watts each, no problem for this cable.
Date published: 2013-11-11
Rated 1 out of 5 by from Poor cheap designInstead of the two wires insulated separately, one wire is jacketed and the other negative wire is essentially bare. When the cable is stripped you have a long segment of bare wire which required two different sizes of heat shrink insulation to deal with. It would have not been difficult to have each wire individually jacketed, similar to what came with the power source for my Musical Fidelity V-Dac.
Date published: 2013-02-24
Rated 5 out of 5 by from It already EXISTS!!I needed several of this connector for a charging station project that I'm building. I found the connector at many vendors but it was over priced and very cheesy. I was pleased as punch to find this cable assembly** at PE for a GREAT price. This item has a cable attached to the connector. That work is already done and it is likely to be more reliable than my work with a poor quality part.Ever onward, ever sideways...
Date published: 2011-12-15
Rated 5 out of 5 by from ExcellentI bought this to connect my Musical Fidelity V-DAC to a Pyramid PS 3KK power supply. It is perfect for the task. (For those who are novices like me, the white stripe wire goes to the red terminal.) Incidentally, the Pyramid does improve the already excellent V-DAC, an excellent way of upgrading the sound on a computer or a DVD or CD player. (Again for the novice: you still need an amp; try the Canadian company Purity Audio.) In any case, this little cable is a capable "missing link."
Date published: 2011-01-12
Does that plug have any spring type contacts inside the hole?
Asked by: I.O.
No, this is a standard barrel type plug. It does not have spring contacts inside.
Date published: 2013-02-13
how do you connect the wires to posts on a pyramid psu???
hi all, like many others, i was attracted to the affordable psu upgrade for my v-dac ii. i am not exactly sure how to connect these bare wires to the posts on the pyramid psu. i know, white sleeved wire to red post. but is it simply unscrewing the posts' caps a little and wrapping wire around the post, and then screwing the caps on tightly?any explanation would be greatly appreciated!!!
Asked by: ayres
It will work by just stripping back the wire and tightening the posts of the power supply down, but fork terminals are usually a little cleaner install.
Answered by: Chrisf
Date published: 2012-11-27
Customer projects that include: 1.3mm x 3.5mm x 9mm Plug with 6 ft. Cord
