13 AWG 2-Conductor Portable Speaker Cable 30m
Brand:|Part # 100-481
This cable is designed from the ground up to guarantee the best possible transfer of signal from your amplifier to your speakers.
List Price$79.99
You Save23%
$61.92
Part # 100-481
This cable is designed from the ground up to guarantee the best possible transfer of signal from your amplifier to your speakers. It also possesses quality materials and superior construction that will provide years of service in all portable and touring pro sound applications. The cable features high strand-count pure copper conductors, and durable PVC insulation and outer jacket. Available by the foot, as well as 30 m (99 ft.) and 100 m (328 ft.) spools.
Specifications: • Conductors: 2 x 13 ga. (50 x 30 ga.) • Insulation colors: black and red • Jacket: Black PVC, 8.0 mm (0.315") O.D.
  • Wire Gauge13 AWG
  • # of Conductors2 Conductor
  • Jacket ColorBlack
  • Length98 ft.
  • BrandParts Express
  • Part Number100-481
  • UPC844632009310
  • Product CategoryRound Jacket Portable Speaker Cable
    (17 Reviews)
  • Weight7.4 lbs.
View similar products to the 13 AWG 2-Conductor Portable Speaker Cable 30m
in the Round Jacket Portable Speaker Cable product category.
13 AWG 2-Conductor Portable Speaker Cable 30m is rated 4.6471 out of 5 by 17.
Rated 5 out of 5 by from Always great stuffThis is my second time ordering this cable. It is a great value, easy to work with and does what it should.
Date published: 2013-08-01
Rated 5 out of 5 by from Great cable for portable useThis cable is high quality and built to last. If you're looking for a cable to connect typical PA speakers, monitors, or instrument speaker cabinets, you'll be happy with this.As other reviewers have stated, the outer jacket completely surrounds the inner wires. This can make the cable difficult to lay if you need it to conform to a certain shape (like around a corner), or if you're used to a cable unrolling and laying flat (like across a walkway). Not a problem for me because I usually tape everything down, and definitely not a show-stopper.Pay attention when stripping the outer jacket so you don't also cut into the inner wires' insulation. If you view the end of the cable, you can tell where the outer jacket is thicker and where it's thinner to plan your cutting accordingly.NYS225B 1/4" connector is a good match for this cable, as is any Speakon connector.
Date published: 2012-04-10
Rated 3 out of 5 by from Cable doesn't lay as well as I'd hopeThis cable has a pair of wires, and the insulation is tightly bound so the cable has a bias to bend or lay straight where the wires are adjacent or parallel to the bend. For instance, the cable wired into a plug in the back of the speaker may stick out if the wires are vertically oriented at the strain-relief, and bend quickly if they are horizontal. It's a nice cable if this isn't an issue in your installation, and I simply remade the strain-relief on a couple of cables to avoid this.
Date published: 2010-03-27
Rated 4 out of 5 by from Good Bargain, Easy to work withI bought this with the help of the reviews I read here. Good heavy duty cable. Relatively easy to strip and work with. I like the foot markers on the outer jackets that make it easy to make equal length cables.
Date published: 2010-01-26
Rated 5 out of 5 by from Way better!Used this to replace some aging wire - it was sounding strange on the left channel. Very happy now with the sound. Very easy product to work with and great results.
Date published: 2010-01-16
Rated 5 out of 5 by from Great cable at a GREAT priceThis is a very high quality speaker cable. The 13 AWG is a good compromise between 12 and 14 AWG. The price of $50 for 100 ft is a steal!
Date published: 2009-12-16
  • 2016-02-10T06:57CST
  • co_hasreviews, tv_0, tr_17
  • loc_en_US, sid_100-481, PRD, sort_mostRecent
