13 AWG 2C Speaker Cable 1 ft.
13 AWG 2-Conductor Portable Speaker Cable 1 ft.
This cable is designed from the ground up to guarantee the best possible transfer of signal from your amplifier to your speakers.
100-482
Weight: 0.1 lbs.
IN STOCK
List Price$1.29
You Save24%
$0.98
Part # 100-482
Qty:  FT
This cable is designed from the ground up to guarantee the best possible transfer of signal from your amplifier to your speakers. It also possesses quality materials and superior construction that will provide years of service in all portable and touring pro sound applications. The cable features high strand-count pure copper conductors, and durable PVC insulation and outer jacket. Available by the foot, as well as 30 m (99 ft.) and 100 m (328 ft.) spools.
Specifications: • Conductors: 2 x 13 ga. (50 x 30 ga.) • Insulation colors: black and red • Jacket: Black PVC, 8.0 mm (0.315") O.D.
  • Wire Gauge13 AWG
  • # of Conductors2 Conductor
  • Jacket ColorBlack
  • LengthBy the Foot
  • BrandParts Express
  • Part Number100-482
  • UPC844632009334
  • Product CategoryRound Jacket Portable Speaker Cable
  • Unit of MeasureFT
    (16 Reviews)
  • Weight0.1 lbs.
View similar products to the 13 AWG 2-Conductor Portable Speaker Cable 1 ft.
in the Round Jacket Portable Speaker Cable product category.
13 AWG 2-Conductor Portable Speaker Cable 1 ft. is rated 4.1875 out of 5 by 16.
Rated 4 out of 5 by from Kind of PainI bought this because it is round and can be pretty much be sealed while running thru a 5/16" hole. You can also buy by the foot. I gave it four stars because it is hard to cut around the the wires without cutting them, ( my suggestion is take small pointy scissors and jam them between the wires forward-wise and cut down the insulation split it and then razor around the speaker wires while pulling them thru the slit ) this worked for me and also what gives with the 13 awg ? Well, can be a good number for me maybe (haven't stripped the wires yet just exposed them, good luck!)
Date published: 2015-04-02
Rated 4 out of 5 by from Great conductors, but difficult jacketThe insulated conductors are embedded in a solid rubbery outer jacket. This makes for a VERYdurable cable, but it takes great care and effort to strip away the outer jacket without compromising the insulation of the inner conductors. Standard jacketing is much easier to work with when attaching 1/4 plugs.The inner conductors are very robust, so if you are willing to take the extra time required to painstakingly strip the outer jacket, you will have an extremely heavy-duty speaker cable.
Date published: 2014-09-01
Rated 4 out of 5 by from Dayton Speaker WireNice wire to go with the Dayton Audio DTA-100A amp. The little amp sounds very good for the size and price but it most likely isn't a high current amp. Therefore I got some large gage cable for less resistance using about 10 feet per side. It's generic cable. Not audiophile grade but still a notch up and it's got the Dayton Audio writing on the jacket which is nice to match up with the amp and Dayton Audio SUBs.
Date published: 2013-10-10
Rated 4 out of 5 by from Good solution for a bass playerI usually make my own speaker cables for my amps and bass cabs, because the guitar stores sell overpriced speaker cables with thin wire and cheap connectors. Besides the cost savings, I do notice better presence in my signal.Until now, I used 12ga generic speaker wire.This cable is good if you need small quantities. I needed 10', so it wasn't a bad price. Stripping the wire isn't bad as long as you have the right tool and patience. I did my two speaker wires over my lunch break. The wire in this cable is 13ga, so it fits easily in my speakon and banana connectors.Since I was using 12ga speaker wire previously, I didn't notice a huge change in my signal or tone. However, I needed new cables for my rig, since I didn't have a spare set. Now I have a nice new set of Daytons and a reliable spare set for my bass amp stack.Another great product from PE!
Date published: 2011-07-25
Rated 5 out of 5 by from Good valueThis cable worked great for making a 1.5' speakon cable. My only complaint is that the insulation on the wires cut very easily which makes it hard to strip back the outer insulation. Had to do it a few times before I got it right.
Date published: 2010-02-16
Rated 4 out of 5 by from Consumer qualityThis is not professional grade wire
Date published: 2009-10-23
  • 2015-06-30T07:39CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.5
  • co_hasreviews, tv_0, tr_16
  • loc_en_US, sid_100-482, PRD, sort_mostRecent
Customer projects that include: 13 AWG 2-Conductor Portable Speaker Cable 1 ft.
