300-583_ALT_0
300-583_ALT_1
300-583_ALT_2
300-583_ALT_3
300-583_ALT_4
300-583_ALT_5
300-583_ALT_6
12" Wireless Subwoofer Package - Dayton Audio SUB-1200 12" 120W Powered Subwoofer + Sub-Link XR
Positioning your subwoofer just got easier, with the Dayton Audio wireless subwoofer package. Two great products come together to add punchy, clean bass to your home theater setup. Installation is easy and the results will blow you away.
  • 120 watt self-powered 12" subwoofer with wireless transmitter and receiver
  • Downward-firing flared port design for clean, powerful bass
  • Selectable "Auto-on" mode
  • Perfect for home theaters or listening rooms
  • All audio and power cables included for wireless signal transfer
300-583
Weight: 46.0000 lbs.
OUT OF STOCK
Due In: 2/10/2015
List Price$269.99
You Save41%
$159.00
Part # 300-583
Your subwoofer setup no longer has to be limited by long cables. With the Dayton Audio wireless subwoofer package, you can place your subwoofer anyplace there is an AC outlet. The setup is simple; just plug the included 3.5 mm to RCA stereo cable into the line out of your receiver and connect it to the Sub-Link XR transmitter.
The transmitter can be powered by the included USB cable/AC adapter, or directly by a USB port on your receiver. Next, place the subwoofer near any outlet within 40 ft. line-of-sight and connect the Sub-Link XR receiver. This can be powered the same way as the transmitter. Connect the receiver to the subwoofer using the included stereo or mono RCA cable. Now, pair the transmitter to the receiver and you are ready to go.
Subwoofer Specifications: • Power output: 120 watts RMS • Frequency response: 25-140 Hz • Box design: Ported • Inputs: RCA line level & speaker level • Outputs: Speaker level • Crossover frequency control: Continuously variable from 40 Hz to 140 Hz @ 12 dB/octave • Phase switch • Auto on/off • Power requirements: 120 VAC, 60 Hz • Dimensions: 16-3/4" H x 16-3/16" W x 17-3/4" D.
Sub-Link XR Specifications: • Transmitter / Receiver operating voltage: 5V DC, 1A • RF frequency band: 2.404 to 2.467 GHz • Modulation: GFSK • Working distance: 12 meters (40 feet; unobstructed line-of-sight) • Transmitter power: ≤ 10 dBm • Transmitter input sensitivity: 700 mV @ 1% THD • Receiver sensitivity: -85 dBm • Frequency response: 15 to 20,000 Hz +1/-3 dB • Delay time: <25ms • THD+N: -60 dB @ 1 kHz. • Dimensions per Unit: 2-5/8/" L x 2" W x 1/2" H.
12" Wireless Subwoofer Package - Dayton Audio SUB-1200 12" 120W Powered Subwoofer + Sub-Link XR includes the following items:
Qty Part # Item
1300-580Dayton Audio Sub-Link XR 2.4 GHz Wireless Audio Transmitter Receiver System for Subwoofers
1300-629Dayton Audio SUB-1200 12" 120 Watt Powered Subwoofer
  • Woofer Diameter12"
  • BrandDayton Audio
  • Part Number300-583
  • UPC848864017174
  • Product CategoryPowered Subwoofers
    (4 Reviews)
  • Weight46.0000 lbs.
View similar products to the 12" Wireless Subwoofer Package - Dayton Audio SUB-1200 12" 120W Powered Subwoofer + Sub-Link XR
in the Powered Subwoofers product category.
12" Wireless Subwoofer Package - Dayton Audio SUB-1200 12" 120W Powered Subwoofer + Sub-Link XR is rated 4.25 out of 5 by 4.
Rated 4 out of 5 by from Exceeded expectationsI needed to upgrade my pathetically underperfoming Sony 8" subwoofer, and after reading many glowing reviews on the Dayton Audio Sub-1200 I ordered it with the wireless kit. It arrived double-boxed only three days after the purchase date and I found it to be a substantial and very well-constructed piece of equipment. The wireless kit was a breeze to connect and it made postitioning the sub in what I deemed the optimal location a breeze. The sub itself is impressive. It provides good LFE texture to blu-rays and 2.1 music listening.. I ran Audyssey to fine-tune my system after inserting the sub into my equipment chain and have the gain at about 50%. I would highly recommend this subwoofer to any audio and home theater enthusiast on a budget--the quality and performance is astonishing for such a reasonably-priced unit. The wireless kit is a great convenience if running cable to a location other than very close to your entertainment center.
Date published: 2014-11-11
Rated 5 out of 5 by from Works greatWireless works flawlessly. Sub fills out the bottom end nicely. Checked draw with the kill-a-watt meter - about 2 watts when off, about 6 watts when turned on, so I just leave it turned on all the time to avoid any "auto on" issues. Outstanding package value.
Date published: 2014-07-26
Rated 5 out of 5 by from Great price for a awesome subwooferDelivered fast and double boxed. Got it hooked up fast except I didn't use the wireless part. I've had trouble getting the wireless part to work and it's probably due to my wifi router like others have mentioned. The sub sounds great and rumbles my house like crazy. I have the crossover turned as high as it goes with my receiver crossed over at 60hz. Within 10 minutes of watching a movie it scared my wife several times lol.
Date published: 2014-07-22
Rated 3 out of 5 by from Pretty good...but one lingering issue.Came beautifully packaged. Double boxed and very fast shipping. The wireless works great although i wish it "auto" shut off with no signal. Reason being that the sub has a notorious reputation (my brand new sub included) that "auto" shut off does not work. I've seen this problem for years so I purchased thinking that they MUST have fixed this issue. NOPE. So I give it 3 stars. The wireless and sub work great!. I truly love them but it bothers me to no end that they can't fix this "auto" feature. Come on!!!!!!!
Date published: 2014-07-13
I just recently purchased the Dayton 12" subwoofer and was wondering if you sold the wireless part by itself
Asked by: fireman
We do, you can see it below.http://www.parts-express.com/dayton-audio-sub-link-xr-24-ghz-wireless-audio-transmitter-receiver-system-for-subwoofers--300-580
Date published: 2014-07-29
My amp doesn't have a line out.Is there a way to use this wireless sub?
Asked by: videoluvr
You will have to have a preamp or subwoofer output in order to use the wireless aspect of this subwoofer.
Date published: 2014-06-09
Customer projects that include: 12" Wireless Subwoofer Package - Dayton Audio SUB-1200 12" 120W Powered Subwoofer + Sub-Link XR
