330-070_ALT_0
12 VDC Tyco 5-Pin Relay SPDT 20/30A (Formerly Bosch)
Brand:| Model: V23234-A1001-X036
This 12V, 30A 5-pin relay is popular for automotive sound and car security system installations. Plastic housing with mounting tab. SPDT, 20/30A.
330-070
Weight: 0.08 lbs.
IN STOCK
List Price$9.99
You Save54%
$4.59
Buy 25-99 $4.00
Buy 100-up$3.82
Part # 330-070
12V, 30A plug-in relay popular in automotive sound and security installations. Plastic housing with mounting tab. Tyco Electronics has acquired the automotive relay business of Robert Bosch GmbH and is now manufacturing this relay to the original Bosch specifications. SPDT, 20/30A. Equivalent to Bosch #0 332 209 150. Product code: V23234-A1001-X036. TE Connectivity part number 3-1904022-2. Made in Portugal.
  • BrandTyco Electronics
  • ModelV23234-A1001-X036
  • Part Number330-070
  • UPC086429006557
  • Product Category12V Relays & Sockets
    (41 Reviews)
  • Weight0.08 lbs.
View similar products to the 12 VDC Tyco 5-Pin Relay SPDT 20/30A (Formerly Bosch)
in the 12V Relays & Sockets product category.
12 VDC Tyco 5-Pin Relay SPDT 20/30A (Formerly Bosch) is rated 4.6829 out of 5 by 41.
Rated 5 out of 5 by from Works perfectly just as original did!I searched far and wide before locating this item here and am I glad I found the Parts Plus website.
Date published: 2014-08-24
Rated 5 out of 5 by from Relays worked great!Shipment showed up right away and relays worked perfect for my off-road lights.
Date published: 2014-05-27
Rated 4 out of 5 by from Not Yet InstalledI hope to get the parts installed this coming week and then will know if this was a good purchase.
Date published: 2013-09-23
Rated 5 out of 5 by from Starter Button installExcellent! arrived on time place in call ....worked like a charm... Love it when a plan comes together thx. Parts Express
Date published: 2013-09-22
Rated 3 out of 5 by from Not as weatherproof/longlasting as BoschI used Bosch brand relays, made in Germany, for 15 years under car and truck hoods and motorcycle fairings...then I gave these Tycos a chance. They're made in Portugal, so a different manufacturing facility with a different design altogether, so I wouldn't say they're comparable to the genuine Bosch relays at all. They lasted two years strapped up under my motorcycle tank with slight exposure to the elements. Once my high-powered headlamp began working intermittently, I had a look and these are corroding from the inside of the relay. (See photo) Maybe the use of dielectric grease or silicon around the contacts is all they need to make them last as long as the Bosch relays.
Date published: 2013-09-07
Rated 5 out of 5 by from 12v 5 pin RelayExcellent product, worked well, no problems, exact exchange.
Date published: 2011-08-02
Which prongs are what?
Asked by: milesrue
You can see the pinout and wiring diagrams in the link below.www.parts-express.com/pedocs/installation-guides/12v-relay-common-uses-with-wiring-diagrams-installation-guide.pdf
Date published: 2014-09-07
Do you have 24V Tyco (formerly Bosch) SPDT relays and the corresponding connectors ? If yes what would be the price ? We need 75 pcs.
Asked by: ShailendraBansal
Unfortunately we do not have any 24V SPDT relays available.
Date published: 2014-06-30
Hi Can I get this relay in a sealed case ? Thanks
Asked by: Jere
We do not currently offer this relay in a sealed case.
Answered by: Chrisf
Date published: 2014-06-06
What are the physical dimensions of this relay, in mm?
For motorcycle application, insalled between top of frame and underside of gas tank. Existing relay is 23x23x23 mm
Asked by: phliparoonie
This Bosch relay measures 28.5 mm cubed and the tab adds to the cube height for a total of 43.5 mm from case base to the top of the tab not including the connnectors.This relay is a true standard for industry because it is reliable. It also has an internal diode which does not allow cross talk if used in conjunction with audio / electrical control circuits.
Answered by: Nitnub
Date published: 2013-09-18
Just wondering how much power the coil draws on these relays
Asked by: Erack
A complete datasheet from Tyco is available, the link I found is too long to include. Simply Google "V23234-A1001-X036 datasheet" and select the second link in the list.
Answered by: RussR
Date published: 2012-08-18
Is this relay a dual-87 output? Or is it 87 and 87a?
Asked by: jjsilver
SPDT=single pole, double throw, so it would be 87 and 87a.87 is NO, 87a is NC.
Answered by: MisterFixit
Date published: 2012-12-15
Customer projects that include: 12 VDC Tyco 5-Pin Relay SPDT 20/30A (Formerly Bosch)
