12 VDC 5A Water Resistant AC Adapter IP67 Wire Leads
Brand:| Model: PS-SP11149
This 12 volt DC, 5 amp regulated power supply is capable of up to 60 watts of power in nearly any environment due to its IP67 water-resistant design.
  • IP67 rated chassis for use in wet environments
  • 12 VDC regulated output with 5A current capacity
  • Overload, over voltage, and over temperature protection built-in
  • Perfect for use with up to 5 meters of SMD 5050 or SMD 3528 LED lighting strips
  • World compatible AC input
320-3146
Weight: 0.88 lbs.
IN STOCK
List Price$59.99
You Save34%
$39.30
Buy 4-up$37.30
Part # 320-3146
This switching power supply is ideally suited for use with LED lighting. With a regulated output of 12 volts DC, and current capacity of 5 amps, this power supply is the perfect partner for up to five meters of SMD 5050 or SMD 3528 LED lighting strips. The fully encapsulated IP67-rated case allows this power supply in nearly any environment due to its dust-free design and ability to be immersed in water up to 1 meter.
Power input is world compatible and able to work with anywhere from 100 to 240 volts AC input. Each power supply is 100% full load burn-in tested and can handle up to a 300 VAC surge for 5 seconds. Two mounting tabs and 23" long input and output leads facilitate permanent mounting. Edison style power cord required and sold separately. CE rated design.
Specifications: • Input power: 100-240 VAC, 47-63 Hz • Output power: 12 VDC, 5A • Dimensions: 6.4" L x 1.67" W x 1.26" H.
  • BrandParts Express
  • ModelPS-SP11149
  • Part Number320-3146
  • UPC848864002651
  • Product CategoryPower Supplies
  • Weight0.88 lbs.
View similar products to the 12 VDC 5A Water Resistant AC Adapter IP67 Wire Leads
in the Power Supplies product category.
This is rated for 12 VDC' 5A.  I have a need for 12 VDC, but with up to a 10 A draw.  Can I safely wire two of these in parallel?
Asked by: Sontiago
I would not recommend wiring two of these together.
Date published: 2015-03-02
  • 2015-03-03T07:39CST
  • loc_en_US, sid_320-3146, PRD, sort_recentQuestionsFirst
Customer projects that include: 12 VDC 5A Water Resistant AC Adapter IP67 Wire Leads
