12 VDC 5-Pin Relay Socket For Bosch Type Relay
Brand:|Part # 330-075
Pre-wired relay socket for use with 12V Bosch type five terminal relays. Three 12" heavy 14 AWG power wires and two 12" 18 AWG coil control wires.
List Price$3.99
You Save25%
$2.98
Buy 10-99 $2.55
Buy 100-499 $1.98
Buy 500+$1.84
Part # 330-075
  • High Current Contact Wires
  • Will Fit All Bosch Type Relays
  • Great For Light Flashers, Door Locks and More
Pre-wired relay socket for use with 12 VDC Bosch type five terminal relays. Three 12" heavy 14 AWG power wires and two 12" 18 AWG coil control wires. For all applications including door lock, light flasher, starter kill, remote start circuits, and much more.
  • BrandParts Express
  • Part Number330-075
  • UPC844632030673
  • Product Category12V Relays & Sockets
    (46 Reviews)
  • Weight0.1 lbs.
View similar products to the 12 VDC 5-Pin Relay Socket For Bosch Type Relay
in the 12V Relays & Sockets product category.
12 VDC 5-Pin Relay Socket For Bosch Type Relay is rated 4.7826 out of 5 by 46.
Rated 5 out of 5 by from Best way to connect teh relaysThese pigtail/socket combinations are the best way to conntect up the Boach type automotive 12V relays. If using in a harsh environment like undet the hood or lawnmower, motorcycle, boat use white grease of other moisture blocking compound as the relay is hermetically sealed, but the contacts can still corrode.
Date published: 2014-02-28
Rated 5 out of 5 by from Does it's job nicelyAll this piece is is an alternative to using five .25" female disconnects on a relay. I like this socket because it made installing some relays for an aftermarket alarm very simple and clean.
Date published: 2013-07-24
Rated 4 out of 5 by from Relay harnessWorks well, but very very snug. After test fit, had to pry it off relay - no good once wired & hot. Found plastic ply tool & keeping in car.
Date published: 2012-07-15
Rated 5 out of 5 by from 5 pin relay socketExcellent product and service, very happy with value.
Date published: 2011-08-02
Rated 5 out of 5 by from Very good product!Purchased these for auxiliary lighting on my truck.Worked very well with the relays, P/N 330-073.Easy install too!
Date published: 2011-08-01
Rated 5 out of 5 by from Great Service!Great service, had problem with shipping, But was Not, company's fault. Replaced Quick. Thanks!!For quick Response.
Date published: 2010-12-28
  • 2016-02-06T06:30CST
  • co_hasreviews, tv_0, tr_46
  • loc_en_US, sid_330-075, PRD, sort_mostRecent
Do you offer replacement crimp on terminals in both sizes?  I only noticed one size on your site & did not appear to the type that locks in the relay socket.
Asked by: Turttle
Unfortunately we do not have any replacement crimp terminals for these relay sockets.
Date published: 2014-02-20
Where can I find this style relay socket with three 10ga wires and two 14/16/18 ga wires?
Will be using Bosh style relay
Asked by: BuzzatApex
We do not carry any sockets with heavier gauge wires. In a typical application, the wires on this socket will be just fine. Constant high voltage over a longer run could present problems, but for this short a length, and intermittent short-term current, they should do the job with no difficulty.
Answered by: RussR
Date published: 2011-07-02
can this be purchased with 18" long wires vs. 12"?
330-075
Asked by: Herbie
No, unfortunately, this item is only available with 12" leads.
Answered by: RussR
  • 2016-02-05T06:52CST
  • loc_en_US, sid_330-075, PRD, sort_recentQuestionsFirst
