12 VDC 4.3A 50W Regulated Switching Power Supply
Brand:| Model: PS-SP11182
This 12 volt DC, 4.3 amp regulated power supply is capable of up to 50 watts of output. 85 to 264 volts auto-sensing AC input. UL recognized design.
  • Adjustable 10.8 to 13.2 VDC regulated output with 4.3A current capacity
  • Overload, over voltage, and over temperature protection built-in
  • Great for electronics projects, especially amplifiers
  • For use with electronics that demand up to 50 watts of power
  • Auto-sensing AC input works with 85 to 264 VAC
320-3147
Weight: 1.06 lbs.
IN STOCK
List Price$34.99
You Save30%
$24.50
Buy 4-up$23.55
Part # 320-3147
This power supply is ideally suited for use with amplifier projects. With a regulated output of 12 volts DC, and current capacity of 4.3 amps, this power supply is the perfect partner for amplifiers with of up to 50 watts of output on tap.
Auto-sensing voltage input for use with 85 to 264 VAC mains power. Overload, over voltage, and over temperature protection is built-in, shutting down the power supply to prevent damage and then restoring power upon recovery. Power cable included. UL recognized design. Output voltage is adjustable from 10.8 to 13.2 VDC.
Note: Minimum recommend power wire gauge is 16 AWG.
Specifications: • Input voltage: 85~264 VAC, 50/60 Hz • Output voltage: 12V 4.3A; 10.8~13.2V adjustable • Dimensions: 5.08" L x 3.86" W x 1.50" H.
This 12 volt DC, 4.3 amp regulated power supply is capable of up to 50 watts of output. UL recognized design.
  • BrandParts Express
  • ModelPS-SP11182
  • Part Number320-3147
  • UPC848864002682
  • Product CategoryPower Supplies
    (2 Reviews)
  • Weight1.06 lbs.
View similar products to the 12 VDC 4.3A 50W Regulated Switching Power Supply
in the Power Supplies product category.
12 VDC 4.3A 50W Regulated Switching Power Supply is rated 3.0 out of 5 by 2.
Rated 5 out of 5 by from Works GreatThis has worked excellent, and has powered my small projects well
Date published: 2015-02-11
Rated 1 out of 5 by from 2 bad units so farSays it is switchable for AC volts in but even after I opened up the case I find no switch. So far $50 spent no DC out from either power supply. I am not ahappy camper.
Date published: 2014-03-11
  • 2015-05-22T09:45CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.3
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_320-3147, PRD, sort_mostRecent
I just received this and it's great. I'm using it with 3 unbalanced to balanced direct boxes. the wall warts that they came with were totally horrible. One question, the unit came with a dc power cord, what size dc plug is on the cord so I can buy more
Asked by: Rosekoi2
This includes a 2.1mm x 5.5mm DC power cord.
  • 2015-05-22T09:33CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.3
  • loc_en_US, sid_320-3147, PRD, sort_recentQuestionsFirst
Customer projects that include: 12 VDC 4.3A 50W Regulated Switching Power Supply
