320-312_ALT_0
320-312_ALT_1
320-312_ALT_2
12 VDC 3A Power Adapter
Brand:| Model: PS-SP11111
12V 3A DC power supply with over-current, over-voltage, and short-circuit protection.
  • High quality DC power supply
  • Convenient plastic case with attached lead
  • Comprehensive circuit protection
  • Perfect for use with Class T amplifiers with less than 36W of output
320-312
Weight: 0.45 lbs.
IN STOCK
List Price$29.95
You Save29%
$21.00
Buy 4-up$19.00
Part # 320-312
12V 3A DC power supply with over-current, over-voltage, and short-circuit protection. Designed for use with the 2 x 3 watt, 2 x 8 watt, and 2 x 15 watt Class-D amplifier boards. Includes 6 ft. IEC power cord. Dimensions: 100 mm (L) x 50.40 mm (W) x 30.90 mm (H). 2.1 x 5.5 mm tip.
  • Current Capacity3000 mA
  • Center/Tip PolarityCenter (+)
  • Plug Size2.1 x 5.5 mm
  • Input Voltage100~240 VAC
  • BrandParts Express
  • ModelPS-SP11111
  • Part Number320-312
  • UPC844632088148
  • Product CategoryAC/DC Power Adapters
    (2 Reviews)
  • Weight0.45 lbs.
View similar products to the 12 VDC 3A Power Adapter
in the AC/DC Power Adapters product category.
12 VDC 3A Power Adapter is rated 5.0 out of 5 by 2.
Rated 5 out of 5 by from Parts Express Cannot Be OutdoneAs usual, when I need a component I turn to Parts Express and they never let me down. They always have the items that a serious tech buyer requires. This case is no different. I needed a solid 12V @ 3ADC supply, and yes! there is was at Parts Express. The product fits my needs perfectly and the shipping is always fast!
Date published: 2013-02-27
Rated 5 out of 5 by from Works great with small amplifiers and LEDsI've used this power supply many times for many different projects. Would highly recommend to anyone needing a 12V power supply.
Date published: 2012-04-12
can this power and amp and charge an ipod?
can this power supply be used to power the Dayton Audio DTA-2 Class T Digital Audio Amplifier Module as well as run power to an ipod dock to charge an ipod or iphone? perhaps with some extra parts?
Asked by: munki114
The DTA-2 requires a 12 volt power supply that gives at least 2 amps. This will fit the bill nicely to power that amp.As for an iPod dock, it really depends on the dock. Most docks are designed to get power over USB, which is 5 volts at up to 1 amp.So, there are a few ways to do this.1-The easy way: Buy an iPod dock intended for use in an automobile. These are made to run off of 11-14 volts, so your 12 volt supply will work great. These can be found with a bit of Googling. Then you can wire the 12v power source right to the dock's power cord.2-The DIY (manly) way: Use a voltage regulator to change your 12v into 5v. I have linked the proper regulator below. Look up the 7805 datasheet for a proper circuit. This will require a bit of soldering, the regulator, a heatsink and a couple capacitors. This will allow you to provide 5v power to a regular USB powered iPod dock.3-The h4xx0r way: You could use an existing 12v->5v transformer, like those intended to allow people to charge USB devices in cars. I have one linked below. Wire your 12v power to the end that would plug into the cigarette lighter, solder securely. Then you have 2 available USB ports on the other end that can provide adequate 5v power to any USB devices that may need it, including a regular USB powered iPod dock.Whatever you decide to do, have fun and be safe!
Answered by: Travis Rysdam
Date published: 2012-08-24
Will this fit the Lepai TriPath amp? It seems to have more current
Asked by: parnelli
This will work to power the Lepai amp. Since this is 12V at 3A it provide 50% more power than the Lepai's included 12V at 2A supply. (36watts rather than 24 Watts)However, I cannot confirm that the barrel connector on the two power supplies is the same.Although, there is nothing stopping you from taking the barrel connector off of the included supply and attaching it to this one if need be. Cut, strip, twist, solder, tape, TA-DA!
Date published: 2012-08-23
What polarity is the DC plug? What size (dia.) is the DC plug?
Asked by: Audio Jock
This is a center positive, 2.1mm x 5.5mm plug.
Date published: 2013-10-31
Customer projects that include: 12 VDC 3A Power Adapter
