12 VAC 3500mA AC Power Supply w/Bare Leads
Brand:|Part # 129-081
This buyout power supply was designed for use with Bazooka powered subwoofers but may be used with low voltage alarm systems and in other applications.
Comparable Items In Stock:
Part # 129-081
  • Designed for Bazooka powered subwoofers
  • 12 ft. combined cord length
  • Can be used with alarm systems
  • Bare wire output
12V AC power supplies are typically used with low voltage alarm and lighting systems. Save over $24 compared to similar power supplies with this exclusive buyout from Parts Express. Combine this 12 VAC power supply with a bridge rectifier (converting the output to modulated DC) to power elaborate LED installations; the AC output keeps extended length wire-run losses to a minimum. Factory buyout—limited quantities!
Note: Power supply designed for indoor use only.
Specifications: • AC power output: 12V • Current output: 3500 mA max • Bare wire output • Combined cord length: 12 ft. • Dimensions: 2-1/4" H x 2-1/2" W x 3-3/8" D.
  • AC Output Voltage12V
  • Current Capacity3500 mA
  • Center/Tip PolarityAC
  • Plug SizeNo Tip
  • Input Voltage120 VAC
  • BrandParts Express
  • Part Number129-081
  • UPC844632098840
  • Product CategoryAC/DC Power Adapters
    (6 Reviews)
  • Weight2.1 lbs.
