299-969_ALT_0
299-969_ALT_1
12" Square Frame Woofer 6 ohm
Brand:|Part # 299-969
Bring your classic hi-fi speaker back to life with this 12" square frame woofer and save over half off the original retail price. Quantities are extremely limited on this Parts Express exclusive buyout!
Part # 299-969
  • Oversized cosmetic trim ring
  • Foam surround
  • Works great in sealed and free air speaker applications, including open back dipoles
This 12" square frame woofer is a perfect replacement woofer for classic, sealed hi-fi loudspeakers! The oversized decorative squared-off frame accommodates a wide variety of OEM driver cutouts, while the 6 ohm impedance makes this speaker work in 4 ohm cabinets and 8 ohm cabinets. Also great for speaker building projects such as open-back dipole speakers. Save over half off the original retail price through this Parts Express exclusive buyout. Hurry, quantities are extremely limited!
  • Nominal Diameter12"
  • Power Handling (RMS)50 Watts
  • Power Handling (max)100 Watts
  • Impedance6 ohms
  • Frequency Response40 to 3,000 Hz
  • Sensitivity90 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)39 Hz
  • DC Resistance (Re)5.03 ohms
  • Voice Coil Inductance (Le)1.29 mH
  • Mechanical Q (Qms)4.9
  • Electromagnetic Q (Qes)1.45
  • Total Q (Qts)1.12
  • Compliance Equivalent Volume (Vas)5.53 ft.³
  • Maximum Linear Excursion (Xmax)3 mm
  • Cone MaterialPaper
  • Surround MaterialFoam
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.75" across flats, diagonally 14.5"
  • Baffle Cutout Diameter10.75"
  • Depth4.1875"
  • Bolt Circle Diameter13.125"
  • # Mounting Holes4
  • Sealed Volume7.38 ft.³
  • Sealed F337 Hz
  • BrandFactory Buyouts
  • Part Number299-969
  • UPC848864006345
  • Product CategoryProducts
  • Weight3.4 lbs.
View similar products to the 12" Square Frame Woofer 6 ohm
in the Products product category.
Part # 299-969
