260-400_ALT_0
260-400_ALT_1
12" Speaker Sealing Caulk Box of 72 Pcs.
Maximize your speaker's performance by eliminating bass robbing air leaks. Speaker sealing caulk creates an airtight gasket between speakers, port tubes, terminals, and the cabinet into which they are installed. Essential for every speaker builder.
  • Speaker building necessity
  • Eliminates air leaks and vibration between cabinets and speakers, ports, and terminals
  • Water-resistant
  • Self-adhering special rubber compound
  • Enough to seal 16 18" speakers
260-400
Weight: 1.8 lbs.
IN STOCK
List Price$14.99
You Save36%
$9.50
Buy 4-up$8.82
Part # 260-400
Eliminate vibration and air leaks when installing speakers, port tubes, and terminals into speaker cabinets with this special rubber compound. Each pliable 1/4" by 12" strip conforms to almost any shape and object, quickly creating an airtight gasket. Longer lengths can be easily creating by combining pieces together. Strips are self-adhesive and stick quite well to speaker frames and cabinets. Sold in boxes of 72 pieces. Enough to seal 16 18" woofers.
  • BrandParts Express
  • Part Number260-400
  • UPC844632098864
  • Product CategoryGasketing Tape / Caulk
    (10 Reviews)
  • Weight1.8 lbs.
View similar products to the 12" Speaker Sealing Caulk Box of 72 Pcs.
in the Gasketing Tape / Caulk product category.
12" Speaker Sealing Caulk Box of 72 Pcs. is rated 4.0 out of 5 by 10.
Rated 5 out of 5 by from It did the trick better ...I already had some foam gasket tape that wasn't quite accomplishing what I needed done. Got the caulking quick enough from P E ...and, abra cadabra, the sealing stuff was just what the 'doc' ordered .... Thanx abunch !!
Date published: 2014-03-07
Rated 1 out of 5 by from Stuck forever........After purchasing this item and installing it, I needed to get back in the cabinet. I had to hack at the edge of the mounting hole o the speaker with a putty knife to get the speaker back out. I CLEANED IT BACK OFF, and reinstalled without the caulk and used felt instead.
Date published: 2013-10-07
Rated 5 out of 5 by from EASY TO WORK WITHAt this time with limited usage, I am afraid to go to far out on my evaluation's. I plan to try some on the rear deck speakers in my car, as that might give an idea of long term flexibility.I also have a couple projects that have been stalled by some surgery, so more data to follow.
Date published: 2013-10-03
Rated 5 out of 5 by from Use this for everythingI have now used this caulk to mount my 3" mids in my dash, my 6.5's in my doors, and some 5 1/4" coax's mounted to a pair of saddle bags for a friends motorcycle. It is easiest to work with if it is a little cold (I actually threw mine in the freezer for a few minutes before using) so it makes it easier to get ff the paper. Be sure you don't squeeze the box or paper wrappers at all, or it will be hard to get off the paper, but that was my fault. Also be sure that when screwing down your speakers, when the caulk makes contact, screw it down slowly to give it time to "squish" so it can spread and do it's job.
Date published: 2013-05-02
Rated 1 out of 5 by from Speaker Sealing Caulk not recommended / Speaker Sealing Tape recommendedI have read several positive reviews for the Speaker Sealing Caulk, but my experience has been the complete opposite, so I must respectfully disagree with other reviewers and share my negative experience, and also recommend an alternative product that I have found to be superior.Although I wanted to like the Speaker Sealing Caulk because it was cheap and easy to apply, in my experience the performance is completely unacceptable. The Speaker Sealing Caulk is very easy to apply, but it simply doesn't work as intended. The primary issue is that the caulk is very soft and remains soft indefinately, so it continues to "squeeze out" from behind the driver flange indefinately. The caulk actually "flows" under pressure from the fastener torque, and as the caulk is squeezed out from the driver flange the fastener torque and driver to enclosure interface continues to degrade over time as the caulk very slowly squeezes out; re-tightening the fasteners back to the required torque simply squeezes out more caulk and restarts the degradation cycle.The Speaker Driver-to-Enclosure Interface is so important that Fastener Torque alone has dramatic impact on loudspeaker performance (several dB# and this impact is measurable, audible and well-documented #see Loudspeaker Design Cookbook#. Since the Speaker Sealing Caulk cannot provide #nor maintain) the necessary driver-to-enclosure interface that proper fastener torque provides, this product does not function as intended and I cannot recommend use of this product. I urge other speaker builders to use PE's Speaker Sealing Tape in place of the Speaker Sealing Caulk.I can recommend PE's "Speaker Gasketing Tape" without reservation because I have found it to be a completely effective product. It is closed-cell foam with very aggressive adhesive on one side, so once the fasteners are properly torque it does not continue to compress over time, and it easily stays on place during assembly. It compresses to a very dense gasket interface between driver and enclosure and maintains this interface quality indefinately.**note: remember that the Speaker Sealling Tape does not compress completely and requires a very slight increase in driver inset depth when routing your enclosure for flush-mounting your drivers.
Date published: 2013-01-03
Rated 5 out of 5 by from Never be without it!I can't count how many different gaps I've sealed/filled with this stuff, speaker-related and non. Same goo that used to be used to seal tail lights to cars-- I've peeled it off, kneaded it, re-used it after 25 years, and it's still sticky! Think of how awful it is to peel off self-adhesive foam tape and its adhesive after a few years, let alone 25, when you consider the price. 3M brand of this same goo goes for almost twice the $. Still not the greatest value considering what it is, but this seems to be the cheapest source for it.
Date published: 2012-12-29
Where's the instructions?
Got your product with no info, no info if there is any harzard to handling properties! What do you use to remove any that gets on cloth, wood or leather/Tolex?
Asked by: ETimms1954
I haven't seen instructions included for this product, but it is easy to use. you simply lay a bead of it around your speaker flange as shown in the PE picture above. You may also want to check out "Plato Indy" review of the product. I can't recommend using this product; in my experience it is messy and ineffective. I recommended an alternative.Cheers,
Answered by: platoindy
Date published: 2013-09-29
How do you get the old stuff off so Ican replace the speaker?
Old PA cabinet has seal on the old speaker that's sealed in. How do I remove the old speaker without damaging the cabinet? It's the same type of seal!
If I understand your question correctly, you are saying that your loudspeaker Driver is still securely fastened to the enclosure: Sometimes glue is used by OEMs and sometimes old gasket material simply compresses and adheres over time, in both cases Driver removal can be tedious, but still doable. I typically take a large, flat, flexible knife and very gently tap under the edges of the driver, going around its entire perimeter to cut loose all the glue/adhesive/gasket between the Enclosure and the Driver, as well as I can (Be patient and careful during the whole process). After loosening the bound between Enclosure and Driver, I use a miniature version of a nail puller (or miniature "wonder bar" as they are sometimes called) and lightly tap it round the entire perimeter of the Driver until the bound is finally weakened to the point I can gently pry it free and remove the Driver. Stamped steel Driver baskets/frames can be easy to bend, so take care not to pry too hard; care and patience are usually rewarded with success in this process.Cheers
Customer projects that include: 12" Speaker Sealing Caulk Box of 72 Pcs.
