10K Audio Taper Stereo Potentiometer 1/4" Shaft
Audio taper 1/4 watt stereo potentiometer with M8 x 6.5 mm L bushing.
023-646
Weight: 0.061 lbs.
IN STOCK
List Price$3.99
You Save39%
$2.40
Buy 10-up$2.28
Part # 023-646
  • Electrical CharacteristicsLogarithmic / Audio Taper
  • Value10K Ohm
  • BrandParts Express
  • Part Number023-646
  • UPC844632080043
  • Product CategoryPotentiometers
    (3 Reviews)
  • Weight0.061 lbs.
View similar products to the 10K Audio Taper Stereo Potentiometer 1/4" Shaft
in the Potentiometers product category.
10K Audio Taper Stereo Potentiometer 1/4" Shaft is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from Impressed with valueEven though my rating speaks highly of this part, I must admit that I have not installed it yet. The part it is replacing, has been repaired for the second time, but has not mechanically failed yet. It will be going into a Spectrum Ail 499 Musical keyboard. This repair will be a modification, but I am more than confident that this will cure the quality problem of the original part.
Date published: 2013-03-19
Rated 5 out of 5 by from 10K pots, good quality at a good priceI shopped around and found these high quality pots at a price better than competitors. They arrived in less than a week, just as described. On the meter, they are very close to 10K, free of noise. The website is a resource worth mentioning, particularly the question and answer section.
Date published: 2012-04-03
Rated 5 out of 5 by from Great product!These dual pots are getting to be quite rare. I needed some for a project I'm working on, and was pleased that they were available at Parts Express!
Date published: 2012-02-17
The pot I need to replace only has 2 terminals on the 2nd layer opp. the shaft end would this still work ?
Could I just not use the center one that mine doesn't have?Also the other problem I see is mine needs to be a splined shaft, is this pot available with a splined shaft?
Asked by: Quinn
It is possible that the 2 terminal layer is a rotary switch. If you turn the pot from minimum to the right and hear a 'click', then it is likely a switch to turn on the unit, and then the pot varies the level of output. Pots by design require 3 terminals for operation.
Answered by: Wolfy
Date published: 2013-10-03
Panning/Balance control
In relation to the previous question asked, does Parts Express even have the correct pots for stereo panning/balance/fader controls? I've searched and can't find anything that's dedicated to this purpose.
Asked by: RhythmJunky
Unfortunately we do not offer any panning or balance potentiometers.
Date published: 2013-03-13
Panning control
Couldn't you flip the other channel's leads around on the pontentiometer to create a panning knob?
Asked by: Wolf Punch
No, this potentiometer will not work as a balance control.
Answered by: CurtisT
Date published: 2012-11-15
Can I use this to lower output of 3.5w tweeters
would like to balance sound of speaker build. It would be a total of 2 tweeters per channel. Is there a better pot to do this with? Thanks in advance!
Asked by: BigGadfly
The easiest way to bring down the level of a pair of tweeters like that would be with a stereo L-pad like the one below.
Date published: 2012-11-05
What are the exact dimensions of the potentiometer? Is there a data sheet with dimensions available?
Asked by: pdrap
Unfortunately, I do not have a datasheet available for this product. It will measure approximately 0.95" in diameter, 1.20" including the terminals. The depth will be 0.90", 1.50" including the shaft. If you require further measurements, please feel free to give us a call at 1-800-338-0531.
Answered by: RussR
Customer projects that include: 10K Audio Taper Stereo Potentiometer 1/4" Shaft
