1000uF 25V High Temp Radial Capacitor
Brand:|Part # 020-1738
High temperature electrolytics for use in switch mode power supplies found in TVs, VCRs, etc. 105° C operating temperature satisfies characteristic W of JIS-C-5141 standards. ± 20% tolerance.
$0.79
Buy 10-99 $0.59
Buy 100+$0.47
Part # 020-1738
  • Standard aluminum electrolytic capacitor series for general purpose
  • -40°C ~ +105°C temperature range
  • RoHS Compliance
Specifications: • Dimensions: 12.5 x 20 mm.
Note: Xicon is phasing out their line of electrolytic capacitors; therefore, we are transitioning to the Lelon brand. Rest assured that whatever brand you receive, your Xicon or Lelon capacitor will have comparable dimensions, equivalent specifications, and RoHS compliance.
  • Capacitance1000 µF
  • Voltage Rating25V
  • Tolerance20%
  • Termination StyleRadial
  • BrandLelon
  • Part Number020-1738
  • UPC844632048517
  • Product CategoryElectrolytic Capacitors
    (6 Reviews)
  • Weight0.0198 lbs.
View similar products to the 1000uF 25V High Temp Radial Capacitor
in the Electrolytic Capacitors product category.
1000uF 25V High Temp Radial Capacitor is rated 4.3333 out of 5 by 6.
Rated 4 out of 5 by from 1000uF 25V High Temp Radial CapacitorGreat price! Great product! Fast shipping!I bought these capacitors to replace several bad 10V ones on the power supply board in my Samsung 46" HD television. I saved about $500 doing the repair myself. My only negative is that the shipping cost is twice what it should be, which made shipping more expensive than the 6 capacitors I ordered.
Date published: 2013-09-11
Rated 5 out of 5 by from Great monitor PS fixA 23" widescreen LCD display goes out, and this simple fix was all I needed. 6x50c caps and it has a new lease on life. Went for the 25v instead of the 16, so these will last longer! They were a little larger than the 16v i replaced, but there was snug room. You can always put heat shrink tubing on the leads and stand them up higher, or lean them over.
Date published: 2013-02-20
Rated 5 out of 5 by from Fixed my Sceptre monitorWhen it comes to caps, size DOES matter.I had to put two of the 1000uf 16v caps side by side, and they fit perfectly. I didn't have as much luck with the 25v cap that I ordered. It was larger than I expected. I had to lean it way over to get it to fit between two other caps.The 25v caps are not the same size as the 16v caps are, but they look the same online. If you can't get a bigger cap in the space that you need to put it, (in between two other caps) you will need to have room to lean it over. Otherwise, you might want to keep looking.All that matters is that my monitor works again. The cap looks a little out of place the way I had to lean it over at a steep angle to make it fit, but I am satisfied with the outcome.
Date published: 2012-01-28
Rated 5 out of 5 by from Fixed power supplyMy mini fridge suddenly stopped working, but before throwing it away, I opened up the power supply. Found a bad capacitor, replaced it with this, works 100% again. Bought 2 in case the other capacitor goes too.
Date published: 2010-03-06
Rated 5 out of 5 by from Worked perfectlyPut these in my Westinghouse monitor and it worked like a charm
Date published: 2009-11-30
Rated 2 out of 5 by from Never really got to use it.It was a good price although shipping was kinda slow. Took 3 days more then was supposed to. Was the same as the one i had to replace. I gave it a 0 on performance because i accidentally hooked it up backwards and it popped as soon as i plugged it in. So that was my fault, not parts express or the manufacturer. But i didnt really lose anything cause of the low price. However it was built pretty solid and i ordered 5 more. So overall a good product but i cant rate the performance cause of my own neglegence.
Date published: 2008-05-11
  • 2016-02-13T07:18CST
  • co_hasreviews, tv_0, tr_6
  • loc_en_US, sid_020-1738, PRD, sort_mostRecent
