100 Hz Low Pass 8 Ohm Crossover
Convenient crossovers that work great in any application requiring economical and flexible filtering.
266-446
Weight: 1 lbs.
IN STOCK
List Price$25.99
You Save25%
$19.46
Buy 4-up$18.53
Part # 266-446
Convenient crossovers that work great in any application requiring economical and flexible filtering. Also for use in car stereo installations with component speaker systems. Low pass, band pass, and high pass models complement woofers, midranges, and tweeters. Designed to be wired in-line between amp and speaker by using .205" disconnect terminals or soldering. The crossovers' compact size facilitates mounting virtually anywhere you desire.
Specifications: • Approximately 250 watts RMS • Type: Low pass • Driver impedance: 8 ohm • Crossover frequency: 100 Hz • Roll off: 12 dB.
  • Crossover TypeLow Pass
  • ConfigurationBoard Only
  • BrandParts Express
  • Part Number266-446
  • UPC844632074875
  • Product CategoryAssembled Passive Crossovers
    (3 Reviews)
  • Weight1 lbs.
View similar products to the 100 Hz Low Pass 8 Ohm Crossover
in the Assembled Passive Crossovers product category.
100 Hz Low Pass 8 Ohm Crossover is rated 4.3333 out of 5 by 3.
Rated 3 out of 5 by from Good for preampI have this cross over hucked up to a onkyo 4 channel amp that is great for mid and highs, with that said the cross overs dont recieve a lot of lowlows.They do a good job at blocking mids and highs at low level, at high levels they clip easil, but if you ran them with a subwoofer amp, or tethered them into a preamp they would do great
Date published: 2014-02-23
Rated 5 out of 5 by from easy to hookup crossover!just as I had ordered. crossover compliments the dayton audio woofer really well. and the ease of hooking it up was a nice feature.
Date published: 2013-03-13
Rated 5 out of 5 by from Just what the doctor orderedI needed to add a passive crossover to some smaller 15" subs so I didnt need a external active one to make them plug and play right off the amp. These fit the bill perfect. I use a set of full range tops on sticks mounted on the subs. So when I dont need to lug a big rack and 18' subs around Im set. The whole PA fits in a minivan for a full band (rock band mind you). I drove these hard and they took it and sounded as good as an active network. My only issues, no mounting holes and the polarity markings are on the bottom. The fix, self tapping screws and a sharpie. Love It! Im buying more.
Date published: 2012-06-15
What Should i get that will give me a high power handling or that will just pass my low frequencies through with no watt limit?
Asked by: EddieAmbition
Off the shelf crossovers will be limited to 250-400 watts of power regardless which model you find. You can either build your own with high power components or go fully active in which case power handling is a non issue.
Date published: 2013-08-29
What does the crossover wattage mean?
I'm crossing my fingers that it isnt how much power it cant handle lol, but if it is What can i buy so that only the hi and mid frequencies are cut out or attenuated with no wattage limit?
The wattage of a crossover is indeed its thermal power handling. We do not recommend more than this rated power fed into the crossover for extended periods of time.
Date published: 2013-08-28
Can I use this crossover for my project.
Hi, I have a set of Celestion DL4 speakers with 6 inch bass/mid range and 1 inch dome tweeter. The speaker has been rated 70Hz to 20kHz. Crossover setting for the DL4 is 3kHz. I wanted to make a new 3 way speaker with the DL4 drivers and 2 way crossover and was wondering if it will make any sense to add a larger woofer driver from Celestion 5 (which I happen to have) with this crossover. Or am I better off getting a 3 way crossover and connect the 3 drivers up that way and forget about the DL4 2 way crossover. Thanks.
Asked by: AlexC
Hello Alex,This network will only work if you were to add a sole-additional sub woofer. think of this as a 1 way network for sub bass only....Add the larger woofer but keep the crossover a 3 way filtering Hi, Mid and low frequencies.My Best...
Answered by: salvatore J
Date published: 2013-07-23
will this work for a older rockford punch- dual coil REP 1212
JUST WANT A SIMPLE ONE WILL RUN THE 2 4OHM COILS IN SERIES FOR 8 OHMS HOOKED TO A sANYO RECIEVER. OR WOULD i BE BETTER OFF WITH SOMETHING ELSE FOR MY SUB JUST MAN CAVE PROJECT
Asked by: TORCHMAN
Yes if you put the two 4 ohm coils in series, the crossover will work just fine. The two coils in series makes 8 ohms of impedence, which will make the crossover a tuned ciruit at the frequency you selected. I have used these on dual 4 ohm coil speakers, and single 8 ohm coil speakers. You will like the results, I did! You can actually use it on a 4 ohm speaker, but the frequency doubles. As an example, a crossover at 8 ohm is 100 hertz, the same crossover should be somewhere around 200 hertz at 4 ohms. Or somewhere close to it.
Answered by: Eddie K
Date published: 2013-03-28
Customer projects that include: 100 Hz Low Pass 8 Ohm Crossover
