10" Economy Speaker Grill
10" Waffle Style Black Steel Speaker Grill with Rubber Edge
Value priced grills are made of .7 mm thick medium duty steel mesh. Rubber edges reduce vibration and facilitate mounting. Sold individually. Mounting kits sold separately below.
260-373
Weight: 0.66 lbs.
IN STOCK
$3.90
Buy 10-49 $2.90
Buy 50-up$2.50
Part # 260-373
Value priced grills are made of .7 mm thick medium duty steel mesh. Rubber edges reduce vibration and facilitate mounting. Sold individually. Mounting kits sold separately below. Actual outside diameter is 10-1/16". Inside ring diameter is 9-1/8".
  • BrandParts Express
  • Part Number260-373
  • UPC844632017490
  • Product CategorySteel Speaker Grills
    (23 Reviews)
  • Weight0.66 lbs.
View similar products to the 10" Waffle Style Black Steel Speaker Grill with Rubber Edge
in the Steel Speaker Grills product category.
10" Waffle Style Black Steel Speaker Grill with Rubber Edge is rated 4.5217 out of 5 by 23.
Rated 5 out of 5 by from Fit and work perfect.I bought these to protect my MTX subwoofers, their enclosure had no protection for them and I often carry items that could damage them in transit. Good metal with rubber edges. I bought the plastic grill holders to attach them and they work great also
Date published: 2014-07-12
Rated 5 out of 5 by from The Perfect Solution!I purchased these grills about a month ago, I have A media room 16'x20' with a 60" 3D smart TV and I use a HK 7.2 home Theater receiver with a Fiber connection to the TV along with 5 Polk Audio surround speakers. I needed some low end Bass to the system so I built 2 sub woofer units from pre-made 1.2 cu-ft cabinets. Got 2 10" sub's from Parts express along with a 70-Watt auto on/off amp and put it all together and was very impressed with the improved low end. I needed to protect the cones so I went with these grills and they are a perfect fit. They are the same diameter as the subs so with a flush mount (Outside) they fit perfect. In addition I got the clamps for the grills and they were the correct height for the flush mount. I just had to supply the screws and now my subs are protected. from my cats or whatever may come. great choice and a really good price.
Date published: 2014-01-22
Rated 4 out of 5 by from Great for the priceGreat for the price. Easy to install. Good quality.
Date published: 2014-01-21
Rated 3 out of 5 by from 10in economy grillcheap price grill for subwoofer box. Fit wasn't great but what you expect for the price. Did some mod and its ok.
Date published: 2013-09-20
Rated 5 out of 5 by from Excellent grills!Heavy gauge steel! Very high quality at an amazing price. Excellent value for anyone using grills in their projects.
Date published: 2013-08-01
Rated 5 out of 5 by from tough little speaker grillI used these to cover and protect back loaded 10" speakers. When mounted on the topside of the box-cabinet the base sits perfectly on the outer edge of the 10 1/8 cutout. I used the plastic mount kit and my own screws. I found that the lateral pressure holds the grills in place nicely because the top of the clip was too tall to touch the top of the grill trim ring when used with back loaded speakers . I would imagine they are that tall to hold down the grill when used on top loaded speakers.hbgb
Date published: 2013-01-28
Customer projects that include: 10" Waffle Style Black Steel Speaker Grill with Rubber Edge
