1 Hz-100 kHz Function Generator Kit
Easy to build deluxe kit produces sine, square, and sawtooth waveforms. Perfect for a variety of audio applications. Continuously variable from 1 Hz to 100 kHz. Maximum output: 2.5 volts peak to peak.
320-118
Weight: 1.0626 lbs.
IN STOCK
Order Soon - Only 3 Left In Stock
$34.25
Part # 320-118
Easy to build deluxe kit produces sine, square, and sawtooth waveforms. Perfect for a variety of audio applications. Continuously variable from 1 Hz to 100 kHz. Maximum output: 2.5 volts peak to peak. Comes complete with all parts, PC board, solder, detailed instruction manual, and deluxe case. Requires 9V battery, not included. Net weight: 1 lb.
  • Project Kit TypeTesters & Problem Solvers
  • BrandParts Express
  • Part Number320-118
  • UPC756619001623
  • Product CategoryElectronic Project Kits
    (7 Reviews)
  • Weight1.0626 lbs.
Handheld Audio Generator
Part # 390-650
View similar products to the 1 Hz-100 kHz Function Generator Kit
in the Electronic Project Kits product category.
1 Hz-100 kHz Function Generator Kit is rated 3.5714 out of 5 by 7.
Rated 4 out of 5 by from Not bad - Does what I needVery easy build. The waveforms are somewhat distorted on some setting but it is suitable for basic testing. I like the small footprint as it saves space on my overcrowded bench
Date published: 2009-10-14
Rated 2 out of 5 by from Excellent directionsI've been building kits since their heyday in the 50's. The instructions are the best that I've seen.Unfortunately, sine-saw does.t work. I have the same distorted wave on both functions. The square wave droops and differentiates on low frequencies.I have n0t, as yet, done any troubleshooting.
Date published: 2008-12-22
Rated 3 out of 5 by from Good valueCertainly, it will not allow you to make precision tests; But it will allow you to hear how smooth your speakers are. (Of course you can put a volt meter on the output.) Kit is easy to assemble.
Date published: 2008-09-07
Rated 4 out of 5 by from Changed part values for operation.I am a kit builder from way back and this was fun to build, although I had a few problems operating the FG-500K. After downloading the I.C. datasheet, I changed a few parts and it works like a charm.
Date published: 2008-03-30
Rated 3 out of 5 by from Not For Serious TestingInexpensive, but has flaws. Sine waves have crossover distortion in the wave form. Square waves have rounded leading edges. Dial calibration is off. If all you want is a source of signals for simple testing then it is OK. Otherwise, skip it.
Date published: 2008-01-24
Rated 4 out of 5 by from good for the priceexcellent for my personal works
Date published: 2008-01-10
what is the ouput impedance? 600 ohms or 8 ohms?
Asked by: raceingreen
The output impedance of this device will be 600Ω, ±10%.
Answered by: RussR
Date published: 2011-09-08
Customer projects that include: 1 Hz-100 kHz Function Generator Kit
Manuals / Resources
Related Products
Customers Also Bought
