CLEARANCE
275-010_ALT_0
275-010_ALT_1
1/2" Inverted Dome Tweeter Element 10 Pcs.
Brand:|Part # 275-010
This 1/2" inverted dome tweeter element is the ultimate in high frequency line array transducers. A minimum footprint allows for frequency response up to (and above) 15,000 Hz without comb filtering, while the low free-air resonance allows it to be used with a large woofer. Sold in packs of 10.
List Price$59.99
Regular Price$29.50
You Save15%
Sale Price
$25.00
Buy 10+$24.75
Part # 275-010
  • Perfect line array tweeter, able to reach above 15 kHz without comb filtering
  • Low 450 Hz Fs for pairing with large woofers
  • Sold in packs of 10
  • Can also be used in slim modern speaker and desktop applications
Speakers in a line array are always limited by their center-to-center mounting distance, driver-to-driver, when it comes to high frequency reproduction. When the wavelength being reproduced by the speakers is physically smaller than the center-to-center distance, the speakers begin to experience destructive interference (which is commonly referred to as comb filtering).
For instance, multiple drivers used in a line array that have a 2" minimum center-to-center distance will begin to experience comb filtering at and above roughly 6,750 Hz. This creates havok on subtle imaging cues, high frequency playback, and top-end sparkle.
This 1/2" inverted dome tweeter element is sold in packs of 10 and are the perfect high frequency element for use in high fidelity line arrays. A 7/8" minimum center-to-center distance allows for unaltered frequency response all the up to and above 15,000 Hz! A low 450 Hz free-air resonance frequency allows you to crossover to a fairly large driver while maintaining seamless integration. The frame design requires mounting the tweeter from the rear of the baffle using a 3/4" opening and securing it in place with epoxy.
Note: Higher power handling and output can be achieved by using multiple tweeters together, and using a 2nd-order 1,500 Hz filter. For example, a series-parallel group of four tweeters will handle 8 watts RMS/16 watts max while increasing the SPL to 72 dB. Two series-parallel group of four tweeters paralleled together (for a 4Ω load) will yield 16 watts RMS/32 watts max (without a filter) and increase output to 78 dB.
  • Tweeter TypeMetal Dome
  • Cone / Dome Diameter1/2"
  • Impedance8 ohms
  • Power Handling (RMS)2 Watts
  • Frequency Response500 to 20,000 Hz
  • Sensitivity66 dB 1W/1m
  • Resonant Frequency (Fs)450 Hz
  • DC Resistance (Re)7.21 ohms
  • Voice Coil Inductance (Le)0.32 mH
  • Mechanical Q (Qms)3.30
  • Electromagnetic Q (Qes)2.58
  • Total Q (Qts)1.45
  • Overall Outside Diameter0.81"
  • Cutout Diameter0.75"
  • Depth0.31"
  • BrandParts Express
  • Part Number275-010
  • UPC844632091551
  • Product CategoryTweeters
  • Unit of MeasurePK
    (2 Reviews)
  • Weight0.18 lbs.
View similar products to the 1/2" Inverted Dome Tweeter Element 10 Pcs.
in the Tweeters product category.
