280-002_ALT_0
280-002_ALT_1
280-002_ALT_2
1-1/8" x 1-9/16" Neodymium Micro Speaker 8 Ohm
Brand:|Part # 280-002
Choose this neodymium micro speaker for applications where size and form factor are critical: flat panel HDTVs, computer desktop or laptop speakers, entryway and room intercom systems... even point-of-purchase displays. Additionally, you can combine multiples of this micro speaker for a line array.
List Price$4.99
You Save20%
$3.97
Buy 10-99 $3.46
Buy 100+$2.98
Part # 280-002
  • Perfect size for slim mount TV LCR speakers
  • Great for use in line arrays with frequency response to 10 kHz without combing effects
  • Micro-sized for small applications and projects
This 1-9/16" x 1-3/16" neodymium micro speaker features a wide dispersion pattern compared to that of a conventional speaker driver and has a decent pass band extending from 20 kHz down to 500 Hz. The low-profile form-factor is ideally suited for thin, flat-panel TV audio applications, use in computer desktop speakers, or mid to high frequency elements of a line-array when used in multiples.
In line-array applications, the minimalist frame allows for a usable frequency response of over 10 kHz without combing. Great for creating maximum impact, minimum footprint tower speakers! A rubberized gasket on the front of this driver allows for rear-mounting.
Note: Designed specifically for rear-mount applications. Cutout dimensions are approximate.
  • Nominal Diameter1" x 2"
  • Power Handling (RMS)2 Watts
  • Power Handling (max)5 Watts
  • Impedance8 ohms
  • Frequency Response500 to 20,000 Hz
  • Sensitivity78.2 dB 1W/1m
  • Resonant Frequency (Fs)666 Hz
  • DC Resistance (Re)6.4 ohms
  • Voice Coil Inductance (Le)0.06 mH
  • Mechanical Q (Qms)3.49
  • Electromagnetic Q (Qes)7.65
  • Total Q (Qts)2.33
  • Compliance Equivalent Volume (Vas)0.0004 ft.³
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialNeodymium
  • Overall Outside Diameter1.125" x 1.625"
  • Baffle Cutout Diameter0.875" x 1.3125"
  • Depth0.38"
  • # Mounting Holes4
  • BrandParts Express
  • Part Number280-002
  • UPC848864000398
  • Product CategoryMini Speakers
  • Weight0.03 lbs.
View similar products to the 1-1/8" x 1-9/16" Neodymium Micro Speaker 8 Ohm
in the Mini Speakers product category.
do the speakers come with the wires or do you have to buy the separate . If the do come with the wires can they hook up to a headphone jack and if the don't come with the wire what wires do i need to hook them up to work for a headphone jack?
Asked by: vane
Unfortunately these do not come with wires. In order to hook them up to a headphone output you will need a small gauge 2 conductor cable and either a 3.5mm or 1/4" male mono plug soldered to the end. These will not have a lot of output if driven only with a headphone output, so a small amplifier is recommended.
Date published: 2014-08-25
Power
Can these speakers be powered directly from the laptop speaker-out or do they require a pre-amp?
Asked by: jimok
You will get the most out of these using a small amplifier. I would recommend something like the Lepai TA2020 below.
Date published: 2013-02-11
What is the mounting depth and RMS wattage of this speaker?
Asked by: GD275
The specifications are blow:Specifications: • Power handling: 2 watts RMS/5 watts max • Le: 0.056 mH • Impedance: 8 ohms • Re: 6.4 ohms • Frequency range: 500-20,000 Hz • Fs: 666 Hz • SPL: 78.2 dB 1W/1m • Vas: 0.0004 cu. ft. • Qms: 3.49 • Qes: 7.65 • Qts: 2.33 • Dimensions: Overall: 1-9/16" x 1-3/16", Cutout: 2" L (including terminals) x 1" W, Depth: 3/8".
Date published: 2013-01-07
  • 2016-02-14T08:00CST
  • loc_en_US, sid_280-002, PRD, sort_recentQuestionsFirst
